I am connecting headphone the sound is not coming .i thinnk some setting problem give me setting step by step
  • 27,725 Answers
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Apr 01, 2011
My ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
No woofer sound from my K3000FX. Verified all cables and settings correct- but sound only comes from tweeter. What could it be?
Step 1:
Hate to say it, but possibly a blown speaker. To check this, do the following -
Step 2:
Insert headphones into jack to verify for sound there.
Step 3:
Unplug unit and open rear panel to reveal speakers.
Step 4:
Remove leads from woofer.
Step 5:
Using a multimeter, set to OHM (horseshoe) to lowest setting.
Step 6:
Apply red(+) and black(-) to speaker leads. Meter should read at least 4-8 ohms of resistance.
Step 7:
If no reading, then voice coil is blown.
Step 8:
If no meter available to use, the use a 9 volt battery by applying direct connection to speaker leads in an off-and-on fashion - You should hear a "click" sound come from speaker. If no "click," then speaker is blown.
Step 9:
If click is heard, and resistance on meter is correct, then the amp circuitry leading to the woofer may be blown = repair needed.
Jan 18, 2013 | Behringer Ultratone K3000fx 300w Keyboard...
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Hi there . please help me as i love these headphones. the sound from one speaker died. by withdrawing the lead one step back the sound comes through both speakers but its not the same tone as before ,...
You're absolutely right, in case the earth cable (the common one from both headphones) is cut, the sound is mono and less bright than the original. You must locate the point of the cable with the problem, cut the cable at this point and connect it at a new headphones jack. In case you can't use a soldering tool for the connections, I suggest to use another cable with the headphones jack already connected, cut it about 20 cm from the jack and connect these leads at the leads you cut before. About the wiring the common rule is that the black cable goes to the grownd of the jack (it's the common cable) and the other two are for the two rest leads. In order to give more details post me back how you are going to handle it (with soldering tool or just cables) in order to give you more details and schematics. A good idea is to clarify the color of the existing cable leads and if possible the availability of a multimeter.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 05, 2011 | Fostex T20RP Professional Headphones
Hello, I can't get sound to my laptop. when I go into the sound controls it's set for Internal but doesn't give me the option to change it?
Check the Sound driver in Device Manager.
Obtain and install the update Sound driver from drivers page.
Open www.hp.com type the product number (eg: AB123UA) in the search field >> Software and Drivers >> Select OS >> Audio driver and isntall it. Restart.
Next...
Restart Audi service
1. Windows key+R. services.msc and press enter.
2. In the right pane, double click on Windows Audi.
3. Stop and then Start. Select Startuptype: Automatic.
4. Apply | Ok.
Next...
Connect an external headphone and check for sound, if working.....
Connect External Headphone.
Play some musich and as soon as the Music starts
Removet he headphone with a slight ****. Check if sound coming from Speaker.
Next...
re-install OS
Next..
Repair
Jul 24, 2010 | HP Computers & Internet
I want to hook up my computer to my dvd
Hi,this is a stepwise description of how to connect your computer to your dvd(home theater system).
STEP 1 Determine the distance between your computer and your system. If your computer is within 12 feet of your home theater system , you can directly connect them.
STEP 2 Make sure there is a free set of inputs on the back of your system. This should be a label that says "Input" and two connectors (usually red and white). Alternateively, they could be labeled "Aux," or "DVD." This is the source that you will select on the front of your device when you wish to listen to sound from your computer.
STEP 3 Determine the length of cable you need. Measure the distance between the back of your computer to the back of your DVD. The cable generally comes in 3-, 6-, and 12-foot lengths.
STEP 4 Visit an electronics store to purchase a Y adapter cable of the proper length. At one end the cable will have a plug to go into the headphone jack of your computer. (The plug will look like the plug on the end of any pair of headphones.) At the other end, the cable will have two RCA-type plugs (red and white). These go into your system.
STEP 5 Plug the computer end of the cable into the headphone jack on your computer. There may be a few jacks; the headphone one is usually green. Connect the other end of the cable to the free set of inputs on the back of your system. Be sure to match red to red and white to white.
STEP 6 Turn on your system and set the volume pretty low so you don't accidentally make a real loud noise.
STEP 7 Select the input to which you connected the Y adapter. For example, if you connected to "Aux," press the "Aux" button on the front of your system.
STEP 8 Adjust the volume of your computer to around 80 percent. You should hear the sound of your computer playing through your system.
Thanks and take care
Apr 23, 2010 | Philips HTS3544/37 Theater System
HP Pavillion dv6110us Speakers not working
The sound power comes through a ribbon cable to the power button,along with the power supply switch wiring. This "power ribbon cable"( part # 431437-001) has frayed where it connects to the motherboard.
The new cable will cost you about $5 with free shipping on ebay and takes about 10 minutes to replace.
You can find step by step instruction on the repair by searching "dv6000 power ribbon removal".
Feb 06, 2010 | HP Compaq Pavilion dv6110us Notebook
I need to get sound incoming with headset how do i do this?
Specifying if this was Windows XP or Windows Vista would make a difference in the fixing of this problem, I am going to explain for Windows Vista hoping that you are up-to-date on the most recent operating system.
Step 1: Locate your task pane in the bottom right corner of the screen.
Step 2: Playback options (I believe)
Step 3: Under "Playback" select your headphones from the list.
Step 4: Right click it and click "Set as default device"
Wallah, it should send the sound to your headphones now rather than the PC's output device, please note, once your not using the headphones anymore you must set the default device back to the normal speakers or you will have no spound.
Apr 27, 2009 | Insignia Bluetooth Wireless...
After using the headphone jack on the side of the TV, I've removed my headphones and there is no sound. When I connect the headphones there IS sound coming from the headphones, but when there is no...
try changing the sound output sometimes the tv will change to headphones only so you have so change it back to the tv speakers your owners manual should tell you how to do this
Apr 15, 2009 | RCA L26HD31 26 in. LCD HDTV
Internal speaker problem
connection frayed
um haard 2 fix if u want i can give u a step by step how 2 fix
just contact me at femi.amoo@gmail.com
Jul 17, 2008 | HP Pavilion dv6000z Notebook
18 people viewed this question
 Grubhead
Grubhead
