I'm not getting the the correct colors printing out it's a **** get versis the correct colors
    Genius:
  • 1,570 Answers
Hi
Just check those low or empty ink cartridges and replace them with new one.
Also, clean manually the print head by the rubbing the print head into a plain paper until ink flows and then run the print nozzle for 2 times to clear the clogged ink.
I hope it helps you. Regards
Posted on Apr 01, 2011
2015 versys, 650 is there a wire kit for both head lamps to work at the same time, and I would to know a good exhaust sys,, low tone, not ear bleeding, zinging noise lol
Hi, Mike for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2015 Versys 1000 LT Headlight Modification
2015 Versys Headlights aka Ninja cyclops
Two Brothers S1R Slip On Exhaust Kawasaki Versys 1000 2015 2016
OEM Parts for Kawasaki
Kawasaki Versys Service Manual
Kawasaki VERSYS Owner Manual
Oct 27, 2016 | kawasaki Versys Motorcycles
Remove calipers on kawasaki versys kle650
Hi, Tony I am sorry you can't find the first and best tool you ever bought for your Kawasaki but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://www.kawasakiversys.com/2007-Kawasaki-Versys-Service-Manual.pdf
http://www.kawasakiversys.com/versys_parts_catalogue.pdf
http://www.kawasakiversys.com/versys-owners-manual.pdf
Dec 31, 2015 | 2008 kawasaki Versys
My monitor diplays lots of blue color
Sunshine versis darker room maybe?
Mar 11, 2015 | HP W2007 Desktop Monitor
We work with Davi-Cash versie 2000 under Windows XP Shortly we will work with new computers under Windows 7. Will Davi-Cash versie 2000 still work?
Davi-Cash versie 2000 is not compatible with Windows 7. You can howeveruse the built-in virtualisation technology of Windows 7 to run a virtual instance of Windows XP within Win7, and run Davi-Cash versie 2000 under that.
May 06, 2011 | Computers & Internet
Why won't the HP Color LaserJet 3500 print photos even with the correct paper
After pressing print you will get a pop-up with a printing preferences button on it click the button and select the correct paper and print quality.
Dec 21, 2009 | HP Color LaserJet 3500 Printer
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Purple Color Printing in b&w mode
When you do nozzle cleaning there is a print test that canon performs. I think it prints out each color. Did the Colors come out correctly? Cuz from there I think you can determine which color is really clogged. I have the solution somewhere but I need to know if the test print comes out correctly or not.
Jul 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Color ink not printing
There is probably dried ink blocking the tubing or print head.
The Maintenance section of your user's guide has a procedure for cleaning the print head and testing the ink nozzles. It may be necessary to have the print head replaced if the maintenance procedures won't clear the problem.
If you don't have the owner's manual, you can download it from Canon on this web page.
Good luck...and I hope this helps!!
Feb 01, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Color printing problem~only green, yellow, blue
TekColor
Description
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
k24674
