Question about ViewSonic G70fmb (Black) 17" CRT Monitor
No color red displays.
I've had a Viewsonic G70fmb graphic monitor for a while. It's really been a wonderful CRT monitor...extra-fine .21 dot pitch.
Suddenly, it has lost the ability to display the color red. Naturally, all the colors now no longer display properly, though the monitor itself otherwise works fine. Any ideas? I could take it apart and fix something, if I new what to look for.
Bill
  • trail_run326 Aug 05, 2008
    Thanks for the great trail of items to check! Maybe I'll get lucky and it's one of the first few (though unlikely, as I've removed and jiggled the cable a number of times, as well as opened up the case and moved things around a bit). Still, it was working wonderfully and faithfully before the color red just suddenly decided to take a hiatus.
    I appreciate your detailed tips. I'll follow your list and see if anything turns up...
    Thanks again.
  • Anonymous May 13, 2009
    I have an Optiquest Q19wb and all of a sudden lost the ability to display red. I've had the monitor for atleast 2 years, maybe 3, and now everything is in greens and blues. I'll try the solutions posted.
  • 659 Answers
If you think that electronic repair is very difficult to learn then you have to read this article where only by using a solder gun could solve a Monitor color problem. Of course there were many tough dog cases (very difficult to find out the fault) in electronic repair but at the same time there were also many cases that can be solve by some simple ways. This G70fmb Monitor came in with no blue color problem. How do I know if the blue color was missing? Simply run a color test (that you may also download from the internet) or from a Monitor testing program generator, you could clearly see as which of the color is missing when you run the color bar test.
A missing blue color in the Monitor could cause the display to turn yellowish. Troubleshooting color problem is one of the easiest in Monitor repairing. Whether the missing color is from blue, red or green there are some areas that you need to check in order to successfully repair it. Here are some of the points that you need to check:
- A bended color pin at the VGA connector. (If pin one is bend then there would be no red color)
- A defective VGA signal cable. If the internal wires were broken then there would be missing colors. You can check if the signal cable is good or bad by doing a continuity test using a multimeter.
- Dry joints in the CRT board such as in the CRT socket pins, video pre amp and driver IC and even at the connector pins. In fact this problem contributed about 80% of Monitor color problems. Applying fresh solder would usually solve the color problem.
- A defective IC either in the Video Pre-amp or Video Driver IC.
- Faulty components in the CRT board. It could be a shorted driver transistor or even electrolytic capacitors that the ESR reading had shot up!
- A bad CRT socket. Sometimes decayed glue could cause the internal pins rusted and thus affecting the colors. Replacing only the CRT socket would definitely solve the problem.
- A weak or a defective picture tube (CRT tube). Yes, I do came across one of the electron gun (most probably the cathode materials had used up) in the tube faulty caused a missing color in the screen. There’s no way to repair this type of problem-the only way is to replace the CRT tube.
- In the newer type of Monitor, color setting is save in the EEPROM IC . Thus, if the EEprom data is corrupted, you would also get a missing color! The only way to repair it is to reprogram the IC or use a soft jig to tune it back the color setting.
Now, which one of the above is the easiest to start with first when comes to troubleshooting the color problem? I believe you would agree with me that the first, second and the third are the easiest compare to the rest. Normally I would hit the Monitor with my bare hands to see if there are any changes in color at the display (be careful not to hit too hard till the casing broken). If there is a change or flashes then I can say that the Monitor has dry joints. And if it stills the same no matter how many times I hit it, I will then starts check the VGA connector and the cable.
In the above Monitor, the problem was dry joints because when I softly hit it with my hand at the side of the Monitor, the blue color immediately appears. The aluminum shielding at the CRT board was opened and I could clearly see lots of dry joints especially in the video pre amplifier and the video driver IC. When you resolder please don’t just touch on the IC’s only, you need to resolder others area as well like the CRT socket pins. Doing this would prevent any color loss again in the future. A good job would prevent call back and to save you time and money and most of all your reputation!
After everything was done, you then need to gently knock at the CRT board again with the plastic handle of the screw driver to see if the color problem still exists. You may also knock on the main board just in case there is any dry joints there. One more thing, if you find that the Monitor is a bit dusty, you may use a vacuum cleaner and a brush to clean up the dirty area.
Whether you are repairing the g70fmb or any other brand of Monitors, if you come across any monitor color problem, you can always use the procedure above to find out the fault. If the VGA signal cable is okay and there were no dry joints in the Monitor, I guess the only way is to use voltage testing method and start checking components with your tester or meter.
Posted on Aug 05, 2008
SOURCE:
The led grenen ligth in front normal is in green / now is in red and the monitor does not work
The indicator color change can mean that there has been a power supply failure
Feb 09, 2013 | ViewSonic PT813 21" CRT Monitor
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
I have a viewsonic g810 21" crt and it will make a snapping noise and the screen will zoom in and back out. How do I fix it?
PLease press reset botton on your monitor display and see any different. hope you find a good result.
Jan 30, 2010 | ViewSonic G810 21" CRT Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
Viewsonic VA2012WB monitor too much red color
I hope there's nothing wrong the the RGB circuitry. Here's what i recommend. degauss, recall the monitor. There's also a temperature setting for the monitor. Change it to COOL or NORMAL.
Mar 15, 2009 | ViewSonic VA2012WB Monitor
No yellow or blue color displaying
In a monitor like crt type. there are three colors amplifier. Red, Green and Blue. I think the Blue color amplifier is defective. Try check the biasing and also the transistor.
Feb 02, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Viewsonic lcd tv 37"
try to check the RAM, video card, or processor maybe it is not properly inserted to the slot.
Jan 08, 2009 | ViewSonic A90f+ 19" CRT Monitor
Color
your monitor CRT gone bad.
Jan 20, 2008 | ViewSonic G790 19" CRT Monitor
if that is a new and have a waranty why did back to the store and need for the replacement if the monitor has a warranty ...so just bring that and need for replacement...
Jan 15, 2008 | ViewSonic G810 21" CRT Monitor
Extra red color in moniter graphics
Hi, is this a CRT monitor? If so get rid of it, there are 3 color beam projectors in the back of the tube if one goes out of commision all color changes and is not worth fixing, second hand CRT monitors are cheap so get one ASAP. Goodluck mistyman
Sep 09, 2007 | Computers & Internet
Open Questions:
See all ViewSonic G70fmb (Black) 17" CRT Monitor Questions
ViewSonic G70fmb (Black) 17" CRT Monitor Logo
429 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
