Maytag Performa PAVT910AWW Top Loan Washer. Level is off on back legs and washer shakes bad thru spin cycle
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 01, 2011
What year is Performa washer model PAVT910AWW
Please check this with the dealer or from the website.
Magtag performa
Jan 21, 2013 | Maytag Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
I have a Maytag Performa top loader that won't stay in balance
make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Oct 06, 2009 | Maytag Performa PAV3200
Maytag lat6914aae top load washer shakes violently in spin cycle
A washer can have self leveling legs at the back. If they are rusty or clogged and not free to move, they will not self level and the machine will rock when working. Check the leveling apparatus, it's a bunch of metal pieces going across the lower back of the machine. Spray them with a lubricant and move them to make sure they are free.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Apr 21, 2009 | Maytag Performa PAV3200
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
Feb 10, 2009 | Maytag PAV2300 Top Load Washer
Washer shakes on spin cycle
2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
2 check the suspension legs at the base of the tub for wear or damage.
Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
Out of balance
have the snubber ring replaced
the reason i say HAVE IT REPLACED is to get to the snubber ring the machine has to be dissasembled and requires special tool to get it apart and back together
Jun 13, 2008 | Maytag Performa PAV2200
Maytag top load washer
This solution applys to many Maytag washing machines. Perhaps not all.
Maytags have three damper pads in the bottom of the machine that must be lubricated from time to time. If they are not, they can be ripped off. They are glued to the bottom of the machine, the drum rests on top of them. When they become dry or lost, the machine shakes violently and no amount
of leveling or load balancing will fix it. Replace and/or lubricate the pads and magically it works again.
This is not a difficult repair for those that have modest mechanical skills and a few basic tools.
replacement pads and lube come in an inexpensive kit.n
I will create a web page with instructions if there is interest.
Jan 28, 2008 | Maytag Neptune Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
