Question about Hyundai Tucson 2005-2007 Radio Dash Kit Metra 99-7315
Radio will not work after battery died.2005 tuson
    Scholar:
  • 116 Answers
You can enter a 4-digit security code as an option after purchase of the unit. If you do so, make sure it is noted down somewhere. If you did select a code (or the previous owner has done so) this must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational. An on-line decoding service may assist you further.
Good luck with it.
Posted on Apr 01, 2011
My 2005 Honda Accord radio dies intermittently followed by the battery dying.
Try disconnecting the battery at night or when not using if it does not drain flat go back to another auto shop that can find the fault, Check the obvious such as the boot light sticking on or the glove box light sticking on even remove these bulbs to eliminate,
Jun 09, 2014 | Vehicle Parts & Accessories
My battery die and i changed for another one but my radio does't work since that day not even appears the code on dash!!2005 acura tl
Check fuses and connections. Probably loose connection when battery replaced. Do you have a radio code that must be entered. Go to Auto Zone and they will check codes for free. If you have an add on amp check for connection to +and grounds and blown fuses
Aug 01, 2013 | Car Audio & Video
What do I need to service my Tuson
service every 12 months or every 10 k .service more if you do lots of stop start work .or at least have the oil and filter changed use fully synthetic oil .there is a full service interval section at the rear of the owners manual
Feb 03, 2011 | 2005 Hyundai Tucson
Airbag light is remaining on when the engine has started. I tryed to manually resetting by disconnecting the battery but this did not help. I have a 2005 hyundia tuson.
dealer only they use encrypted software on later models from 2005 and although you have a OBDII plug under dash its only for show or the american market for the emisions test ,The actual diagnostic plug is under the bonnet with a fancy shape thats copyrighted so no made up bits for aftermarket readers.Doesnt help general mechanics like myself much
Aug 28, 2010 | 2005 Hyundai Tucson
My rack and pinion on my 2005 tuson went out only 29 thousand miles is that normal it is three months out of warenty
No, it's not normal but it happens. If you find a decent dealer it may take a part of the cost for replacing it.
Aug 12, 2010 | 2005 Hyundai Tucson
Honda Odys 2005 DVD Player doesn't work
Unplug the battery for one hour and plug back it, it should work.
Mar 26, 2010 | 2005 Honda Odyssey
Where do i find the code, my radio went off when my battery died
you have to pull the radio out the numbers should be on the back of the radio then you have to call the dealer
Jul 04, 2009 | 2005 Honda Civic
1999 Pontiac Sunfire won't even turn over, but the
The radio will work even with a dying or discharged battery.
First, be sure to check all of your fuses in the engine compartment.
A full battery will keep the headlights bright with the engine off. With a dying or discharged battery, the headlights will be noticeably dim.
When you turn the key to crank the engine, does the starter try to turn or make a fast clicking? If so, the battery if low or dying. If it makes a slow click then stops, then it's REALLY dying.
If you don't have a battery charger, go to Walmart and get some jumper cables. Hook up a friend's car to yours. If it starts, then the battery was low, either from a bad battery or a bad alternator.
If it doesn't, you have electrical problems, possibly a bad starter or starter solenoid.
Jun 30, 2009 | 2005 Pontiac Sunfire
Battery and Air conditioner will not work in Infiniti G35
my radio ad a/c works only same times for ten minute and then turn off and no works maybe until next day
Apr 01, 2009 | 2005 Infiniti G35
Hyundai Tucson 2005-2007 Radio Dash Kit Metra 99-7315 Logo
517 people viewed this question
Top Hyundai Car Audio & Video Experts
David Burbee
David Burbee
Jude24
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
