Question about Vulcan Kitchen Appliances - Others
Pilot is on, thermostat click but the burner didn,t come on please help thank
  • Vulcan Expert
  • 684 Answers
Try to tighten wiring connections on gas valve, thermopile, hi limit and thermostat, if it does not correct the problem, try replacing the thermopile first then if the burner still do not fire up, replace the gas valve.
Posted on Apr 19, 2011
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2012 | Imperial IFS40 Deep Fryer
The oven/stove is from the 70's and the pilot light is on but the oven will not heat up. help
Thank you for bringing me back to the early days of my appliance repair career,now a days every thing uses a electronic ignitor and its been a while since i have seen a free standing pilot :)
As far as your oven,when you turn on the oven does the small pilot light increase in size,if not the oven thermostat is the most likely problem and for the most part the thermostats are no longer avaliable. If the pilot size increases the pilot burner could be not properly heating a small bulb in the pilot burner,the pilot burner could be cleaned by a senior tech that knows how to do it correctly OR the small bulb is heating and what that the bulb attaches to (the gas safety vavle) is not opening to allow gas flow to the main bake burner
Depending on your exact model (what parts were used when it was built) the pilot burner and gas safety valve are still avaliable
Gene
Jul 30, 2011 | Tappan Kitchen Range
Right, front flat burner does not light and barely heats. My Hotpoint stove is five years old and gets very little use. What's wrong? Can I fix it? Can you help?
Hello and Welcome to FixYa!
Please provide us with the model details of your unit and What exactly, you are facing. Is the burner properly getting the supply. And is it partially lighting or didn't lighting at all. Is the unit repaired ever since the problem started? Some details of the trouble, you are facing, will help suggesting more precise solutions to the problem,
Feel free to Ask,
Concerned.
Jul 15, 2011 | Hotpoint Kitchen Ranges
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Apr 01, 2011 | Vulcan EF3 Deep Fryer
My friend has a mobile home that has an Intertherm model #4139000 no manual but th pilot light is lit but and the fan motor kicks n on run only not on auto, the burner never fires up. They changed th...
If your friends heater has a pilot light but no burner I would be inclined to change the gas valve. You need to get the proper gas valve for mobil homes. They require a two stage slow opening valve. Make sure it is set up for the right type of fuel. If possible have someone with experience working with gas to help you with repairs. I hope this helps you some. Thanks
Nov 19, 2010 | Heating & Cooling
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
I have a 3 burner pitco gas friolator and dont know how to light the pilot any suggestions
First, never light when the pot is empty, you can fill with water if you have no oil. Open the door, check the thermostat and make sure it is turned off.(The burners will light if thermostat is on) Behind the thermostat you will see the gas valve. Turn knob to off, then to pilot. There is a notch at the pilot position. Now look up in the middle behind the burners and you will see the pilot assembly. Push in on the knob on the gas valve while you hold a long lighter close to the pilot assembly. Once the pilot lights keep holding the pilot knob in for 20 seconds. Now let off the pilot knob. Pilot should stay burning. Now turn the gas valve from pilot to on. Now turn the thermostat to desired temp and the burners will fire off and start heating.
Oct 15, 2009 | Kitchen Appliances - Others
Lang gas pizza oven.. Main burners won't lite!
Hello. It sounds like, from what you said, you have a new thermocouple. The device it is attached to, the pilot safety, could have a problem internally that allows gas to the pilot, but does not open the main part of the valve, or electrically has failed on the main coil. If you have a thermostat with wires on it, you can jumper the wires, to bypass it, temporarily please, if it comes on, you need a thermostat, if not, it is the valve most likely.
Hope that helps, and thank you.
Feb 18, 2009 | Bakers Pride FC-616 Gas Single Oven
Kitchen Appliances - Others Logo
197 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
