Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
I have 2 MV11C Radios and 2CLS1110 Radios and i cant get them to work together. Could you please tell me how to get them all on the same frequency and band with so all can work together? Thanks so much
I believe that MV11C is a vhf radio and CLS1110is a uhf radio. You cannot make them communicate.
Posted on May 06, 2012
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Look at your manual go to frequency Ch#1 say: 462.5625 mhz. Try all radios on 462.5625 mhz that is standard Ch#1 on all FRS type radios. Just keep it locked on that Frequency. I don't think anyone eavesdrops on it anyway.
Posted on Apr 02, 2011
What is the frequency for this radio what ever came with it
These are programmable radios that require Motorola software and programing equipment that is only available through a Motorola dealer. A reputable dealer should be able to help you reprogram the radios with the appropriate frequencies and codes for your use.
Dec 08, 2013 | Motorola MU24CVS UHF (4 Channels) 2-Way...
How to connect t5620 to T5420
First as I'm sure you know the two radios must be on the same frequency. The easiest way is to reset both radios so that no tones are being used to block unwanted calls from coming in to each radio. next select a channel on the T5420. This radio only has the 14 FRS channels where as thee T5620 has all 22 GMRS channels of the FRS are the interstitial frequencies between the main GMRS channels. So, you can ONLY use the 14 common channels between the radios. It would be a good idea to look at the manuals for each to make sure they call the channels the same numbers for the frequencies they are using. I can't imagine that they are not, but you never know.
I do not have these radios or the manuals all I did was look up on the web what kind of radios/FCC service they were designed for.
As long as all tones or codes are removed and you are on the same channel (the same frequency) these radio will be able to "talk" to each other. Once you get them working together then try adding a tone to call each to see if they are using the same tones as well. They do not have the same number of channels so they may not even have given the channels the same numbers between the two different radios, again the manuals will tell you. If you do not have the manuals search the web for them, they should be available from Motorola if nowhere else.
Nov 14, 2013 | Motorola Talkabout T5620 (7 Channels)...
Zartek 705 and 708 2 way radios
The 705 will operate on (8) frequencies in the 446Mhz range and (5) in the 464Mhz range. The 708 operates on 446Mhz. Please note that the links provided mention they operate in "public frequency band" of South Africa. These radios were not intended to be used in other countries. See below for more.
In the U.S.(and many, many other countries), the 420Mhz - 450Mhz frequency range is set aside by the FCC (and other bodies) for licensed operation by amateur radio operators. Portions of the 460Mhz range is set aside by the FCC for use by Public Safety Agencies - mostly local police and fire departments. In the U.S., the Family Radio Service (FRS is 462Mhz) is an unlicensed band and General Mobile Radio Service (GMRS is 467 Mhz) requires a licensed.
As you might have guessed, unlicensed or unauthorized transmissions are ILLEGAL. You may be fined, imprisoned or both if caught by the FCC. If using these radios in a location other than South Africa, consult that county's communication authority BEFORE transmitting. You cannot transmit legally in the U.S. with these radios.
Nov 11, 2013 | ICOM Informatique Radio Communications
COBRA MICRO TALK1 FRS 100
THEY SHOULD ALL WORK TOGETHER ON THE FRS FREQUENCIES. MAKE SURE THAT YOU SET THE CHANNELS AND SUBCHANNELS TO THE SAME ON ALL FRS RADIO.
Oct 07, 2012 | Cobra Frs-120 Microtalk 2-mile 14-channel...
What Motorola Radios are compatible to use with Motorola MV11C
NoCfghhjjfddf Gadsden cdsfgvhjb fdsffcc Cfghhjjfddf fccffcg
Jul 17, 2012 | Motorola MV11C VHF 2-way Radio
I have a motorola mv11c and it works fine and I just purchased a pair of motorola mv21cv. They must be on a different frequency my question is how do I change the frequence on my mv21cv radios to be...
Hold in the PTT button while you turn on the radio. It will announce the frequency number. You can use the PTT button to change the number. Then press the Monitor (small possibly red) button to lock in your setting. The next number your radio announces will be the Code. Use the same method to change the code if needed. Then press the Monitor button to lock in your setting. Once you have set both your freq and code you can turn the radio off, then turn back on normally and use the radios.
Best regards.
Jul 22, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
I cant connect my two walkie talkies, how can i do talk between my two motorola t7150
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T71xx.pdf Programming instructions begin on page 19. Your frequency and code must match identically for the radio to work together.
Best regards.
Jan 13, 2011 | Motorola T7150 (22 Channels) 2-Way Radio
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
Comunicating between different models, can it be done?
sometime your program is wrong... so plz go this website and u can get soft the prob :)
this website have sofware :) so nice man!
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Jun 13, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
119 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
