Question about Radio Shack Pro-97 Handheld Scanner
My pro 106 scanner has a few channels that give me static noise how due i erase them
BillB-SA
  • 2761 Answers
SOURCE: programming pro 106 scanner
Your scanner covers conventional frequencies as well as a variety of trunking systems. Programming steps can be detailed, and they vary according to the system being worked, so it's not practical to attempt a full programming tutorial in this short response. Your best bet is to review the operating manual for the scanner, and then follow the steps for the system(s) that you want to program. If you run into a specific problem, let us know and we'll do our best to work through it with you.
Need the manual? You can download/print it here:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000106_PM_EN.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Posted on Dec 24, 2009
  • 1274 Answers
SOURCE: pro 106 police scanner I can't program it
Try this, press HOLD, then enter the channel you want to store the frequency, then press the FUNC and PGM button, the channel number appears, use the number key of the frequency including the decimal point, then press E to enter..you can get your frequency's at www.RadioReference.com ....hope this was helpful....
Posted on May 26, 2010
  • 8 Answers
SOURCE: Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
Posted on Aug 05, 2010
BillB-SA
  • 2761 Answers
SOURCE: I have a radio shack
You can initialize the scanner to delete all information that you've programmed into it and return it to its original factory settings. To do this:
1. Turn the scanner OFF, then turn it ON again.
2. Press and hold down the CLEAR key and insert a pointed object, such as a paperclip or the point of a pen, into the RESET opening in the back of the scanner, and press the button inside the opening.
3. Release RESET. When information reappears on the scanner's display, release the CLEAR key.
NOTE: You must release the RESET button before releasing the CLEAR key.
Also note that this procedure may not be necessary. Programming a new frequency into a channel automatically deletes the frequency previously stored in that channel.
Bill B
Listening in since the 60's
Posted on Oct 05, 2010
Testimonial: "Perfect solution for what I want to do. Thank You"
SOURCE: programing Radio Shack Pro 106 scanner
call radio shack store 620-669-8850 ask for mike the manager during the day or carl in the evening about 6;30pm they will help you what ever problem you are having with the pro 106 digital police scanner
Posted on Feb 26, 2011
Pro 106 police scanner I can't program it I have tried everything and can not get it programmed. nothing but static
May 21, 2010 | Radio Shack Pro-96 Scanner
SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
Mar 25, 2010 | Radio Shack Pro-94 Scanner
Which is the best sanner the pro96 or the pro106
I own both of these and like the 106 more. It isn't just because it is new, but it has several options that make it more "user friendly" as well as better features. Some of the high points are:
-Easier manual channel navigation
-Larger, easier to read display
-Easier scan list understanding
-Much better user interface (text menus)
-Colored LED that you can assign to different channels..such as your priority channels. This way you can see what your receiving at a glance without having to actually look at the display,
-Remote control capability using the Win500 software.
A Pro-96 is a good scanner, but the Pro-106 blows it out of the water.
Jan 26, 2009 | Radio Shack Pro-96 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Programing Radio Shack Pro 106 scanner
As an employee of Radioshack, I have found that you can use scancat lite to progrom the pro 106. Programing conventional trunking systems work well with this system. However after three days of frustration I did find out how to program the digital channels. After programing the conventional channels in, you will have to program the digital channels in manually. Do not program the group id's into the scanner, just leave it in a "wildcat" search. When the group Id shows up while listening to the scanner push enter and that will program the Id in. When you got the all the Id's that you need, then program the scanner to a private mode, this will let you to listen to just what you want to listen to. I am still working on finding better solutions.
Dec 29, 2008 | Radio Communications
Radio Shack Pro Scanner
I know that if you turn your scanner off over a few days you can loose your frequency # or it will lock the channels out. if they or l/o just unlock then. I also know that all police and ect. went digital, you would to have a scanner that is digital. When they changed to digital some for the frequency # have changed. I had to get the new ones and put them in.
k.ditterline@yahoo.com
Jun 08, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
53 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
