Question about U-Line BI-95
Hi I have a u-line BI 95 ice maker it runs well gets cold and the thermostat cut the compressor in and out but does not make ice! I disconnected the water line after the solinoid thinking that water may come out but nothing? What could be the problem? I have tried changeing the tempreture and also ajusting the ice block size. how can I check if the soliniod is working? is it 12 volt?
4 Suggested Answers
SOURCE: BI-95 ULINE
raritan eng/whirlpool ice maker assembly
Posted on Jul 12, 2008
  • 286 Answers
SOURCE: Give-me plis a wiring digram manual of the Ice
Your going to call U-line and ask for it. 800-779-2547. Now what are you trying to do? I can give you the wires on the thermostat. Terminal 1 is red(icemaker) Terminal 2 is yellow(common) Terminal 3 is blue/black(compressor and cond fan motor) When yellow and blue or black are closed this will run the compressor and fan.Thermostat is satisfied then the red and yellow are closed and it advances the icemaker. Ejector blade at the 12 oclock calls for freeze cycle. at 2 calls for heater to come on(inside icamaker) at 10 oclock it trios the water switch and calls for water.Then back at 12 oclock calls for freeze cycle. Temps should be 10-15 degrees in the bucket. Warmer the setting the more ice it makes.
Posted on Jun 30, 2009
  • 286 Answers
SOURCE: uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Posted on Jul 07, 2009
Will not get cold. the compressor isrunning all the time and will not make ICE. It has a brand new ice maker unit in it, thermostat, and watervalve from last year.
A BI 95 will run until the thermostat is satisfied. The it closes contacts between red and yellow to advance icemaker. Make sure thermostat is set at a warmer temperature. 10-15 degrees is what your looking for in the bucket. After you turn it down and it doesnt cycle then make sure it wires right. Red terminal 1 yellow terminal 2 blue/black terminal3 Or it could be to warm (heavy frost needs defrosting) If everything is running and not cooling then a sealed system is expected. Also make sure you have the right icemaker if not then that could cause everything. Sensor needs to be in the tube about 12 inches.
Aug 12, 2009 | U-Line BI-95
I have a u-line bi-95 ice maker.the machine will only drop ice once after it is turned on. i also notice it gets very hot near the vent.the machine does get cold enough inside to keep the ice.what should i...
Your unit will only harvest when your thermostat is satisfied. If you have heavy frost you need to defrost the unit. If no frost then make sure the fan is running by the compressor. If the fan isnt running then the compressor is going off on overload. Or it could be the fan running but the compressor is not. If thats the case you will need a service tech.
Aug 03, 2009 | U-Line Icemaker
Have a bi95 water not going throught inlet valve,hose is clear to freezing tray. took valve apart did not see any obstruction. any suggestions? thanks mike55
The valve assembly for U-lines shouldnt be taken apart. Now the first thing is to advance the icemaker. Remove the cover off the icemaker head. (pry and pull at the same time) use a 5/16 nutdriver or socket on the small gear. Turn it counter clockwise. Whent he ejector blade reaches 1 or 2 oclock it should take off by itself. When the ejector blade reaches 10 oclock then it calls for water.
(ejector blade is the fingers that push the ice out)
How a bi 95 works is the thermostat need to be satisfied first. Then it advances the icemaker. Turn it to the warmest setting. If its set too cold then it would run and never be satisfied.(warmer the setting the more ice it makes) Everytime the compressor cycles off the icemaker should be advancing. If not then the thermostat could be stuck in the freeze mode.
T-stat Terminals 2 is yellow(common)
3 is blue/black (fan & compressor)
1 is red (icemaker)
2&3 closed freeze cycle
2&1 closed harvest mode
Jul 10, 2009 | U-Line Icemaker
Give-me plis a wiring digram manual of the Ice Maker U-Line BI-95
Jun 30, 2009 | U-Line BI-95
U line BI 95 icemaker is making but not ejecting made Ice
First thing to do is find the temp in the bucket. Should be between 10-15 degrees. If its colder then try turning the thermostat to a warmer setting. If its warmer than this then the unit is not getting cold enough. Look at the cendenser to make sure that its clean. If thats good you might have to check the thermostat. (if its 10-15 deg) Check the wiring. red goes on terminal1 yellow on 2 and blue /black on 3. The control might not be switching to harvest position. Wait until you hear the compressor and fan shut down then look at the icemaker. If not advancing then replace the thermostat.
Apr 30, 2009 | U-Line BI-95
U-Line BI-45A won't run
check the wiring diagram at the back panel. trace each component.
you could have disconnected one or two wires while replacing the fan, check the thermostat control. see if there is continuity. check the wirings also that went there.
tnx 4 using fixya,
drcool
Oct 19, 2008 | U-Line Icemaker
Electrical wiring diagram for BI-95
U-Line Emailed me the wiring diagram.
Oct 06, 2008 | U-Line BI-95
U-line ice maker BI-95
hi,
try to steady your thermostat setting to the lowest or not turned at all. more stock in your ref. can help your ice maker not to frozen. if you have less stock in your ref. put some gallons of water. or put your ref near the fire bin but not too close. or with a circulation of hot air
Sep 19, 2008 | U-Line Refrigerator Ice Maker
BI-95 ULINE
Jun 20, 2008 | U-Line Icemaker
U-Line BI-95 Logo
63 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
