Question about Canon CanoScan LiDE 600F Flatbed Scanner
When scanning a document I get a message "3 documents cropped. Transferring 2/3 docuements." I have our original settings but I can't get out of this loop. How can I resolve.
SOURCE:
legna
  • 53 Answers
SOURCE: scan document
Is very hard to alter a scanned document if you are not sure how to, especially without the help of an editing software. but try to scan it to text if you have Word it sure will help, scan it to Word and after is saved you can type or erase certain portions of the document, browse trough the tools tab to search for the option that will suit better the type of work you want to do on your document. If you have Adobe Acrobat Professional this is very easy to do, you only have to scan the document on Adobe format and using the advanced editing tool.
Posted on Dec 06, 2007
old marine
  • 2237 Answers
SOURCE: Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
Posted on May 08, 2008
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Posted on Jul 17, 2008
  • 111 Answers
SOURCE: scan and make changes to document later
You need to use OCR. Use the OmniPage Se application that shipped with your scanner.
Posted on Oct 29, 2008
SOURCE: Canon MP500 keeps cropping scanned docs
i was having the exact same problem -- very annoying! just go to the following link and follow the instructions. VERY quick and easy!!!..... http://support-au.canon.com.au/contents/AU/EN/8000507501.html
Posted on Feb 10, 2009
How do I scan multiple documents and email them as one attachment
1. Click PDF on the Custom Scan with One-click tab or click PDF in the one-click mode screen to open the PDF dialog box.
* If you wish to convert the text in a document to editable text data, scan the item with the OCR. The precision of OCR is affected by the nature of the scanned original
2. Select the type of document to be scanned.
Important
To scan correctly, select a document type that matches the document to be scanned.
3. Select a file type to save the scanned image.
Select PDF, PDF(Multiple Pages) or PDF(Add Page)
Important
Click Set... to open a dialog box and specify the PDF compression type and other advanced settings for creating PDF files.
4. Place the first original on the scanner and click the [Scan] button at the right bottom corner of the PDF window.
5. When scanning is completed, place the next original and click the [Scan] button.
6. Repeat scanning by clicking the [Scan] button until you finish all the originals.
7. When all the original is finished, click the [Exit] button.
8. When the scan is complete, it automatically starts the application program that displays PDF files and opens the scanned image file in it.
To scan a text document or black and white document, you are recommended to set the Scan Mode to Black and White or Grayscale.
You are recommended to limit the number of pages in any one multiple PDF file to 20 or less if you are scanning a color document with the Image Quality set to 300 dpi and the size to a setting equivalent to Letter size.
Aug 07, 2013 | Canon MP Navigator EX for Windows
Hello, I am attempting to scan an important document and the printer keeps saying "set the document on the platen glass" the document is there but it keeps saying the message
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
May 01, 2011 | Canon Pixma MP480 All-In-One InkJet...
Hp scanjet 8250. I want to set my scanner to default to PDF when I am trying to email. That is the way we do most of our scanning and right now it defaults to RTF.
Have you considered simply scanning from within Adobe Acrobat or similar software that produces .pdf and then use the email feature within Acrobat?
As I look over the HP User Manual, I can't see any method to set the default output. It simply says...
Use the E-MAIL button() to scan documents or pictures and insert them in an e-mail message as an attachment. You must have an Internet connection and a supported e-mail application.
1. Place the original face down on the scanner glass or face up in the ADF. If you are scanning two-sided originals from an ADF, slide the DUPLEX switch to two-sided mode.
2.Press the E-MAIL button().A message appears asking if the original is a document or a picture.
3.Select Document or Picture, and click OK.Note:A preview image will not appear when scanning from the ADF. To change this preview setting, see the HP Photo & Imaging software Help.
4. Select the final scan area (the area inside the dotted lines) in the preview image.
5. Make adjustments to the preview image if needed.
6. Click Accept.The final scan area is scanned and your e-mail application is opened. The scanned image is added as an attachment to the e-mail message.
7. The Save As dialog box appears. Type a file name and choose a file type, and click OK.
8. Complete the e-mail as usual.
Aug 07, 2009 | HP Office Equipment & Supplies
Scan letter
Most scanners in my experience do not scan to "precisely" 8 1/2 X 11 inch letter size (assuming that was the original paper size).
A workaround is possible with some graphic programs. After importing the original incorrect scan of the document into the software a combination of resizing and/or cropping (depending on how your program works) will allow getting the exact dimensions. Then save as a new image document. Make sure to adjust for sufficient resolution (a larger document) if you plan to reprint.
Jul 25, 2009 | HP Officejet 5610 All-In-One InkJet...
How can i copy a legal document with cannon MF3200
you can print legal document through print command go to print property and give command on legal size.
but you can't scan legal document in single go.
if it urgent to scan in legal scan it in 2 parts then join using some software like corel draw or word.
Jun 10, 2009 | Canon MF3110 All-In-One Laser Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
IS760 How to scan a 2-sided document
Well, the right answer will depend on what equitment you using to scand. Let me know what you are using.
Jan 19, 2009 | Ricoh IS760 Flatbed Scanner
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Automatic Cropping...
Before turning off the autocrop feature, reset the software to the default setting. Then turn off the autocrop feature. Some scanning software need to be reset to the original default condition and accept software switches only then!
S. Mohan
Dec 05, 2007 | HP ScanJet 8270 Flatbed Scanner
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
Clive
Clive
old marine
old marine
