Question about Whirlpool Refrigerators
Hi My fridge is 5 year old ,at present the cooling is poor ,only the upper door gets cooling but not frosting the cubes .what the problem would be ,the service man says that we have to refill tha gas and also we have refilled the gas a year ago.I dont know wether the service man is correct,and how much would it cost to refill the gas Plz help me understand the correct problem and take the best decision Thanks
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
My side by side fridge is not cooling at all. The fan is barely blowing out cool air. It started with the freezer yesterday and now the fridge is doing the same. I tried by turning the temp dial all the...
Hello Racinfrogs,
You are most likely looking at a serious FROST blockage...
FIRST thing to check... YOUR DEFROST pan...
If dry... you have found your TROUBLE..
A serious FROST
blockage can be caused by SEVERAL
air intrusion issues... Ice cube stuck: holding chute door open... or a pizza box holding any door ajar... Perhaps even a failed (or poorly aligned) DOOR GASKET...
(all these will be burdening your defrost pan: lots of water)
FINALLY... and very common
A DEFROST CIRCUIT FAILURE.
(this will be manifested by a DRY defrost pan)
Easiest... Part to check & change
Your REFRIGERATOR has a defrost timer...
Check here for replacement part (wp67001036)
and INSTRUCTIONAL VIDEO...
http://www.appliancepartspros.com/whirlpool-timer-defrost-wp67001036-ap6010261.html
In addition to their instructions.. I always SUGGEST
you should take pictures and notes of what COLOR
wire goes where... BEFORE getting in trouble...!!
There are only 2 (two) other parts to the defrost circuit...
EASY once you understand...
- Thermal switch to keep defrost temperature v-low
- heater element (ungoverned can ruin food/plastic).
Hope this helps... ELSE comment me
back BEFORE getting in trouble.
Pricewise (using part number) also check eBay
Genuine Amana Whirlpool Defrost Timer 67001036 WP67001036 PS2063117 eBay
Carnac the Magnificent
Sep 21, 2017 | Amana ASD2622HRQ Side by Side Refrigerator
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not cool enough
Make sure the air door in the refrigerator compartment is open at least a little and not blocked by anything. This is located just to the left of the bottom drawers. Also check the air inlet located at the top left rear of the refrigerator for flow. If none is present then you have a frost buildup caused by frequent opening and closing (common to these models) an ice cube dispenser door hanging partly open (Also common). Check this by looking from the inside of your freezer door down the ice chute. A flashlight helps a lot here. Also may be a defrost issue.
Mar 05, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrgierator is not cooling enough
Is the frost on the entire surface of the evaporator or just a portion. If it is only frosting on a portion there is a possibility your system has developed a leak and has lost some of the charge. Or your compressor has lost its ability to pump the gas. A bad condenser fan motor overtaxes the compressor and can cause premature failure. If it is a bad compressor it may be time to replace the refrigerator. Replacing the compressor is an expensive job and the warranty is only one year on a replaced compressor.
May 31, 2008 | GE Profile PSW26P Stainless Steel Side by...
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Refrigerators Logo
222 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
