Windows will not reconigize Hitachi hard drive. when i plug it in to a usb port?
    Guru:
  • 433 Answers
Clean your usb port
must be reconigize
good luck
Posted on Apr 01, 2011
Divice not reconiged
plug it again and if it doesn't work at all try other USB port. A USB flash drive nowadays supports only 2.0 and above USB ports. It all about signal speed a USB 2.0 and above were backward compatible with USB 1.1 .
May 27, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I lost my Hitachi 500gb driver, can I get a driver so as to recognizing it with windows 7.
Just connect it -- it is a Plug-and-Play device, and Windows 7 supports Plug-and-Play.
Do you get any error-messages when you connect it?
Does it connect to some other computer?
Does some other USB device connect to the USB port that you're using for the Hitachi?
Dec 18, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Windows can not reconiged
The drivers of the pen drive might have been corrupted. Pl do check for that.
May 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
USB's slow and external drive
For the USB ports, you may want to verify that the drivers for the "enhanced USB" are up to date and for USB 2.0 or 1.1. USB 2.0 ports are generally backwards compatible for 1.1 devices. The "enhanced" does indicate USB 2.0 controller. 30mins to backup 3GB to your external drive is a VERY long time. USB 2.0 transfers data up to 480mbps, but if you get an error message indicating that the device can perform faster on a 2.0 port, you maybe transferring data at 12mbps which is USB 1.1 speed
To speed up the transferring of data, identify which USB contoller in Device Manager is the USB port you're having a problem with, and delete it from Device Manager. Then, plug in your external drive into a USB port its never used before.
As for the naming of hard drives, Hitachi partners with several drive manufacturers including Dell and IBM.
Feb 22, 2010 | Philips Computers & Internet
External hard drive device installer error
Has it got its own power supply or is it using a two USB ended cable. It could be your laptop cannot supply enough power via one USB port so that it really needs a two ended cable so that two USB ports will power it up. Try this Mark
Aug 18, 2009 | Hitachi 0A52126 120 GB SATA Hard Drive
USB drives Not working
this problem seems mostly with the usb mouse, the best solution is to plug the flash drive in one port and usb in other and restart the computer generally this always works but if it wont work then the best thing is i also did that, buy a 4-port usb hub and connect it with laptop and connect your usb mouse with this port not directly to your laptop and when you like to use your flash drive plug it in the laptop.
this is working with be perfectly and i hope it will do the same at your side.
Mar 23, 2009 | Toshiba Satellite A135-S2326 Notebook
Problem with Hitachi 1TB external hard drive
Most likely you just burnt up the adaptor. You can order another one from Hitachi.
The data is probably still intact on the drive itself.
You can connect it to your computer with an adapter that plugs into the drive itself and the usb port on your computer. It then shows up as a drive letter as normal.
You can buy these sata to usb adapters at most computer stores for around $25. Tiger has a nice selection:
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=sata%20to%20usb%20adapter
I would pick one with an external power supply. It also connects to your hd. The ends are keyed so you can't miss-plug them.
Or find a local computer tech (most have this cable in our toolkit) and he probably will copy your data in a few minutes for you.
Sep 04, 2008 | Hitachi 1TB External USB 2.0 Hard Drive
Is my hard broken before i have got a chance to even use it?
However rare, it is possible that you have a dead hard drive. I would try the hard drive on a different computer (one that has a known good set of USB ports). If that still does not work, take it back to where you got it and get a refund/replacement.
A couple of things you can look at:
1) Do you hear/feel the hard drive "spin-up" when you first turn it on ?
2) Does the hard drive come with an external power supply ? If so, it could be just the power supply that is shot. Check for tell-tale LEDs that would say whether it's working or not.
3) Have you tried different USB cables/USB ports ? Sometimes the front ports do not have enough juice to power a hard drive (if it's drawing power off the USB port). Sometimes switching to a USB port on the back of your computer is enough to solve the problem.
4) Make sure to eliminate as many superfluous components you can from your testing: don't plug the hard into a USB hub, plug it directly into an motherboard USB port (as mentioned above, the ones on the back).
Hope this helps.
May 18, 2008 | Hitachi 200GB External USB 2.0 Hard Drive
External HDD
I have 2.5" HItachi 120GB and the same problem !!
Nov 16, 2007 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
