Question about Epiphone SG Special Guitar Electric
I have an Epifhone SG special, red When I play on the top of the neck the pitch can change up to half a tone. Only by picking a tone on the top it is is very sensibel. I noticed the arm moves a lot more than my other guitarrs. Is this normal with this model? If so can I do something about this? Gustaf Gullander
  • Epiphone Master
  • 5,603 Answers
You mention an "arm" but the websites do not show any "arm" on the SG specials... If you mean a bender arm, your guitar has probably been modified and maybe done so incorrectely. The problem sounds like one of "intonation" which has to do with the lengthwise positions of the saddles at the bottom although a hallf tone is a lot to be in error from this. Watch videos on YouTube about guotar setup or take iit to a guitar shop to have it setup correctly. You can DIY this.
Posted on Apr 01, 2011
I need the wiring diagram for an Ibanez AS153 semi hollow body, where can I get one?
the 153 is wired like a Les Paul or SG
2 humbucker, 2 vol, 2 tone
with the addition of a 3 way coil tap for the neck pick-up
wired similar to:
http://www.guitarelectronics.com/product/WIRING_MOD_HB0066/Guitar-Wiring-Mod-HumbuckerOFFParallel.html
Aug 16, 2016 | Ibanez Artstar Series AS153 Semi-Hollow...
Tone knob and switch info
the switch, has three positions. Typically forward or up will be your neck (or rythm) pick ups, only and will work with one volume knob(usually top right as your looking at guitar), and one tone knob ( top left as your looking at the guitar). when the switch is in the far right or all the way down position, that will be the saddle (or lead) pick-ups. And that works with only one volume knob(bottom right as your looking at the guitar) and the corresponding tone knob. when the switch is in the middle position, botjh volume knobs work and both tone knobs work. You've gotta kinda play around with them to find whatever sound yopur looking for. and tone knobs are very subtle in their changes. good luck
Aug 26, 2014 | Epiphone Sheraton II Guitar Electric...
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
Mar 28, 2014 | Seymour Duncan ShPg1 Pearly Gates Pickup...
How to adjust truss rod on yamaha f335 guitar
Taken from http://www.learnguitarsetups.com
There are a few golden rules when adjusting your truss rod. First, only use the rod to keep your neck as straight as it needs to be...do not use it to adjust your action! Second, only use the proper tools. If you do not know what the proper tool is, check with the manufacturer. Truss rod nuts are easy to strip, and once they're stripped, they are expensive to fix! Finally, do not force anything; an eighth of a turn can make a drastic change. Remember, if the truss rod feels tight or doesn't seem to be doing anything, take it to a professional.
  1. Start by sitting with the guitar in the playing position.
  2. Tune it to pitch if it is not already.
  3. Capo the first fret. If you do not own a capo, you can use your fretting hand.
  4. Next, fret the bass string with your picking hand up near where the neck joins the body. This is typically around the 14th fret, but it may be higher up with some electric guitars. In our example, we'll be using the 20th fret.
  5. Use the string as a straightedge held against the neck which will either bow away, or against the string. This is how you determine the amount of relief in the neck. You can also use a steel ruler placed along the length of the neck, in the same manor.
  6. In our example, the approximate half way point between the 20th fret and the 1st, will be the 7th fret where we will observe the distance between the top of that fret and the bottom of the string (or ruler), as pictured. Notice the gap. Hint: Half way down the neck is often between the 7th-9th frets.
  7. If you have a gap between the top of the fret and the bottom of the string, you likely have a bowed neck. If there is no gap, it is likely either dead straight or back-bowed.
HOW MUCH TO ADJUSTThe bigger the gap, the more relief is in the neck. Normally, we want just a small amount of relief in the neck for optimal playing, about the same as the thickness of a business card or less.
If there is a gap, tighten the truss rod clockwise until you have something closer to what we're after. Slide a business card in between the top of fret and bottom of the string (or ruler). Make sure you are placing the card parallel with the string or ruler. If there is no gap, you may be either dead straight or back bowed, so you will need to loosen the truss rod counter-clockwise to get the results we are after. Hint: If the strings are buzzing in the first few frets and open strings, it is often a clear indication of a back bow.
Remember, do not force anything to get the results you are after. If it is hard to adjust or spins freely you may need professional assistance.
The final step in setting your relief is to test it out! If it feels better, you're done! But take note, straightening the neck may actually make your guitar play worse! Consequently, when the truss rod is tightened, the height of the strings are lowered, which can create string buzz if your guitar isn't setup properly to start. Likewise, it can make a poor fret condition more noticeable. So, if your guitar plays worse after adjusting the neck, it is either too straight for your playing style, or it is a sign that more work is needed. Thankfully, you can easily reverse the changes you've just made if required.
For pictures and further info, visit www.learnguitarsetups.com
Dec 16, 2012 | Yamaha Music
I changed pickups in my robot, now it doesn't tune. what could the problem be?
The on-board computer that senses pitch is designed to work with the stock pickups. Changing them makes the computer unable to "hear" the pitch, and therefore unable to automatically tune itself.This is a common problem, but a Gibson authorized technician should be able to correct the problem.
Hope that helps!
Nov 13, 2010 | Gibson Robot SG Special LTD Ebony
I have an older gibson sg electric guitar -can not find a serial number-not o n back of neck-where could it be?What kind of value? 2 effect switchs by knobs-
The number should be on the neck reinforcement chrome plate on the back. It seems it may have been changed before you owned it. US built ones have 4 buttons Yours has two so it is foriegn made
May 25, 2010 | Gibson SG Standard Electric Guitar with...
I want to do a set up on my sg 400 - what are the recomended string hights - pick up hights ect
First of all make sure your gtr. neck is perfectly strate. to ck. this site down the neck like the berral of a gun. to should have no concave to it at all. if it has then you will have to deal with that first.
But lets just get to the other spect hopeing that all is well with the neck. #1 string height is measured at the 12th fret.you will need a mm gage. at the 12th the low E string or 6th string should be at 2.00mm and the high E at 1.5. use a view of sight to get them at even heights.The pickups are between 2.5 and 3.00 mm. use a alan wrenck to rais and lower the strings at the saddel. DONT use a philups screw driver on the horazontal screws with springs.This is your intonation. if you get this messed up your gtr. will never play right. I hope you can do this , good luck. if this helps please rate me tK. u DFD
Apr 11, 2009 | Music
Old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
Nov 10, 2008 | Yamaha Electric Guitar
Epiphone SG Special Guitar Electric Logo
Top Epiphone Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Robert Graf
Are you an Epiphone Music Expert? Answer questions, earn points and help others
