Question about Video Game Consoles & Games
The DVD unit keeps trying to load and then an error comes up that says "no disc" and there is a disc in the unit??
  • 6,993 Answers
Are you referring to a DVD player? If yes, read further. if no, please let me know.
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Apr 01, 2011
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
Hello! I am trying to record movies from my VCR collection to make them on the DVD format. I place the tape in the VCR ...then add a "brand new" DVD into the DVD tray (Sony DVD+R)...I then...
You are probably using a disc format which is not compatible with this model unit. Try using DVD-R instead of DVD+R. That should eliminate your error - and work fine. Give it a try - at this stage it is most likely a set of incorrect DVD formats (you can keep any unrecorded/remaining DVD+R discs for your PC (if it supports them) and use them as data storage).
* Single layer DVD-R 4.7GB/120min/4-16X discs are relatively cheap in a spindle tub (25 or 50 discs) available everywhere. *
The good news is no repair costs at this stage.
Apr 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Wont play a disc. It will stay in Loading mode for minutes and then read "No Disc"
Try to play a music on cd instead of playing dvd. It it plays keep playing until playey got hot and drive off moisture on circuit. Let it cool down then try play dvd. If it can play severy dvd in sequence, then your unit is repaired. Keep using it to avoid condensation inside the dvd player.
Nov 15, 2010 | TruTech LMD-5702RT Portable DVD Player
My dvd player keeps trying to load the disks but comes back saying "NO DISC" it worked earlier on the same DVD is there anything I can do?
Take the DVD Disc that say NO DISC put some dish washing soap,clean all the grimes,dirts and smushes off of the laser side of the shinning surfaces of the DVD Disc.Clean it with a towel,wait like about ten minutes,tried play the disc again,it should work now.
Nov 04, 2010 | Mustek MP100 Portable DVD Player
Load dvd disc, dvd reads disc then comes up with
I am just wondering whether the unit has got condensation inside.
Just try to do this as a process of elimination.
Take the dvd and place in a warm room.Plug it into the mains (try and eject disc if not leave in) and leave for 2-3 hrs
Give it another try..fingers crossed.
Dec 04, 2009 | Panasonic DMRES15 DVD Recorder
Error 14
Check to see if you are using 16X media. If so contact Toshiba for a fireware upgrade. If that is not the problem try cleaning the disc and cleaning the unit with a DVD Laser Lens cleaner. Then try again.
Mar 30, 2008 | Toshiba DR4 DVD Recorder
Video Game Consoles & Games Logo
42 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
