Calibrate a nyko super cobra gun for area 51 to 55" flat screen mitsubishi. when the trigger to the gun is pulled the screen flashes and makes noises as to register the gun is there, but we cannot get it to actually fire at targets on the screen. screen just flashes and makes "reload" noises..
  • 1388 Answers
SOURCE: Trigger problems
I have repaird hundreds of nail guns with a problem similar to yours. Depending on the brand and model, the problem can be repaired by checking the following. Headvalve orings should be checked for wear and any surface that the orings contact must be smooth and free from scratches. If the surfaces are scratched try to smooth with fine sandpaper and use light grease instead of oil when assembling. The safety contact foot may not be reaching high enough into the trigger to properly push in the trigger button. Check for worn spots on the trigger that may be filled in with epoxy, loose fitting trigger caused by worn roll pin or retaining pin. Some of the trigger valves as used on many bostitch nailers (tva6 valve) used a plastic pin which contacts the trigger. If this pin is loose or worn the valve should be replaced. Some tva6 valves have a vinyl looking sort of oring that fits too loose on the spool. This vinyl oring in not available by itself but if the oring fits too loose the gun will not fire and leak air. On bostitch remove the trigger and the rollpins holding the trigger valve and apply air to gun to eject valve. (use heavy glove to catch valve as it will come out with force)
Posted on Nov 25, 2008
SOURCE: No target appears on the calibration screen
I just got one of these for my 4 yo daughter and had the same problem after 2 days. GOOD NEWS IS IT IS FIXED. The problem was crumbs stuck between the edges of the screen and the frame piece around the edge of the screen. I assume this was creatintg pressure in 2 places at once, confusing the screen/software and not showing a target on the calibration screen.
I used a toothpick to remove the visible crumbs, but if you have a can of compressed air used for computer cleaning, than that might be even a better idea. It seems that screen problems were chronic back in 2004, but no so much now. I learned about this here: http://www.watercoolergames.org/archives/000028.shtml
GOOD LUCK and post back if it works as it is simple and maybe some of the other people with problems have ths same simple issue.
Posted on Dec 29, 2008
jj505
  • 195 Answers
SOURCE: paslode fixing gun has stopped firing
Do you have gas cylinder in,if so is gas expiration date on bottom of cannister,change gas to current fresh date. Also open nose of nailer and see if a fastner has logged ,remove and push plunger pin back into body,be sure to remove battery during these tests.
Posted on Mar 19, 2009
  • 25 Answers
SOURCE: nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
Posted on Apr 19, 2009
  • 20 Answers
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Posted on Aug 17, 2009
Gun identification from serial number
Make sure it is unloaded!
Gun will show the make near the trigger. The barrel will have the calibre, this is essential for using the correct ammunition. The model number is normally there are well if it is a hand gun, but not normally on rifles or shotguns. Armed (excuse pun) with that information Google
Make model calibre serial numbers.
COMMENT below my name if you need any further help as I will get a notification.
Sep 30, 2016 | Optics
Hitatchi nv45b2 trigger leaking
Air leaking around the trigger area could be caused by vinyl ball / gasket under trigger valve bushing or orings within the gun. Easy test, remove nails and connect air (assuming that air is now leaking around the trigger area). Depressing the trigger stops the leak, replace vinyl ball. Depressing trigger does not stop leak, move plunger b (plunger B, small shaft under bubber bushing next to the trigger valve) with your finger in then out to determine if air leak changes tone. If air leak changes sound or tone, then air is leaking past orings of the cylinder guide and/or cylinder plate and/ or the cylinder itself is scratched by debris where the orings make contact. Pull out the cylinder and examine the contact areas. If scratched, use 300 grit paper to smooth, if smooth, however, suspect the orings of cylinder guide (or cylinder guide is cracked). The cylinder guide is difficult to remove and install without causing damage to guide or cutting new orings when installing. Do not remove the guide unless all the other options have been checked. One last bit if information, I have noticed that some guns will leak air if the orings on the feeder piston do not fit snuggly. Make sure that leaking sound is not coming from feeder area (remove the basket and feeder/feeder pin/spring and pull out the feed piston, making sure that the largest oring is making good contact within the cylinder). Good luck with repair.
Sep 28, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
Cobra gun repair
DOn't know anything about guns, and I've never heard of a gun manufacturer name Cobra. You are posting in a CB RADIO area. Your solution would be found in an area about guns.
Nov 29, 2011 | Cobra Radio Communications
Just bought a MadCatz Dreamcast Light Gun - no matter what I try it won't calibrate, just flashes on the screen when the trigger is pulled. Any thoughts ?
The gun could be broken. However, if you're trying to use it on a flat-screen TV (LCD, Plasma, or Rear-Projection), those TVs are not compatible with light guns. You must use an old-style CRT TV.
Jul 13, 2011 | Mad Catz Video Game Consoles & Games
Miller 350p welder gives a "help 3" code.
Code help-3 Indicates that the gun trigger was pulled and held during power up. Release gun trigger and clear fault condition. Also, this display can Indicate no open circuit voltage detected when gun trigger is pulled and no arc detected within 3 seconds, this means that the trigger was held without any metal contact. The machine will shut down in order to avoit the wire to continue to run freely.
To fix:
Turn on the machine without pressing the trigger on the gun. Then increase to the max the wire speed. Then turn off the machine. Press the trigger after the machine was turn off, then without releasing the trigger, turn on the machine and release the trigger after 2 seconds. That will take care of it.
Nov 17, 2010 | Miller Welding Tools
Duofast ms 7664c staple gun still blowing air out
This series of nailers are the most difficult to repair. Your nailer has twice as many orings as the norm. Many have said that this nailer is over-engineered. There are three areas that could cause trigger area leak. To make it simple, lets do one area at a time. Use soapy water around the trigger area to find actual leak. If air is leaking from actual trigger valve (ms719-2) and its counterpart, the cartridge (ms719-1) then these two parts need to be removed. Check for scratches in the metal of the valve. If scratched try to remove with fine paper or replace as necessary. Most leaks are due to faulty trigger valve. If air is not leaking from actual trigger valve then remove the dump valve (mn120-5) at the back of the head of gun. There should be two small allen screws then metal lid, then spring and oring. Pull out dump valve and make sure all the orings are in order. This valve should be able to move, not too tight. Use silicone paste lube on all orings (available at Lowes in plumbing department, Danco brand used for faucet orings). Reinstall dump valve and related parts and check for leaks. If air seems to be leaking from bottom of gun neer trigger, most likely problem is cycle valve (mm419-1) and related vinyl seat. These two parts are in the valve housing under the trigger. This valve also moves within its housing and seats on a vinyl oring. This part could be clear vinyl or black rubber. New seats are clear. Inspect these parts for scratches/cuts and lube with silicone paste. Hopefully you would have solved the problem with trigger valve. Good luck with your repair and do not dispare, this is one of the most difficult guns.
Jun 18, 2010 | Duo Fast Air Tools & Compressors
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Light gun support
tv has nothing to do with it,,sounds like you need a new gun for it ,,
Apr 04, 2009 | Acclaim Virtua Cop with Stunner for Sega...
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
