Which is the compatible output transistor of c 5552. thanks
    President:
  • 2,992 Answers
NTE2642 or ECG2642 can replace a 2SC5552.
Posted on Apr 01, 2011
Is AVG compatable wit aspire 5552-3691
Yes. I use AVG on both the Acer laptops in our household
May 09, 2014 | Acer Aspire 5552-3640, 5552-3691,...
One side dead
hi zm_16dec,
Right chanel fully dead , output transistor burnedout ,
Without knowing the make and model of your amplifier
all i can advise is to replace the unknown part number of
the transistor.
Look for the working left channel output transistors and
replace the bad transistors in "pair". These may include
other components but check on it as well.
Check the speaker system, especially where that channel
is connected.Inspect speaker wires or cable up to the speaker
itself.
Amplifier wont blow without reason.It could be from the wirings,
speaker or volume settings of the unit.
Thanks for choosing Fixya for assistance!
Dec 24, 2012 | Audio Players & Recorders
What kind a outputs transistor use a QSC Gx3 power Amp
this power amp uses 2SA1962 and 2SC5242 output transistors. You can download the schematic diagram from this website.
Thanks.
gylacz
May 10, 2012 | QSC GX3 Amplifier
N-5552 microwave is how many watts
N-5552 does not exist but NN-5552 does.
There is a label on the back of the microwave that states the power output.
I have had a look on the web but cannot find the information you require, sorry.
Dec 30, 2010 | Panasonic Microwave Ovens
HORIZONTAL TRANSISTOR BLOWOUT
If the "Chopper" transistor repeatedly "Blows" it is usually because the LOPTy (Line Output Transformer) is faulty, usually a short. OR a shorted Diode or Capacitor, in the driver or output.
Feb 13, 2010 | Televison & Video
Hello....
If you disconnect the speaker wires from the speaker terminals on the amp and the amp still goes into protect mode, the amp probably has shorted output transistors. If that's the case, the amp is probably not repairable. The outputs that Sony used were discontinued and there are no other transistors that will work properly (unless some of the newest transistors are compatible).
If it's under warranty, contact Sony. If it's out of warranty, contact one of the authorized Sony service centers to see if they can help. They may have a supply of NOS parts that would work.
Nov 23, 2008 | Sony XM-DS1600P5 Car Audio Amplifier
Denon AVR-3105 Unit tries to come on but after a few seconds power LED flashes red. (Unit shuts down) I found transistors Q1015L and Q1035L in the output circuit shorted. However, replacing these...
Look for open resistors in the same area. Also, if the transistors that you replaced are the output transistors, you should replace their compliments as well. I don't have the service manual with me at the moment, so I'm juist giving you generalities. If you can, lift the center pin of the output transistors and measure (and post) the voltage readings on each of three pads for each transistor. That should give me enough info to guide you further.
Thanks,
Dan
Oct 07, 2008 | Denon Audio Players & Recorders
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
Lg 5552 v set is dead
try to resolder all points in fbt including fly back trans itself area also resolder the crt pcb area i had the same problem the reason was cold soders also put a good 2sc5297 for hor out.
Dec 02, 2006 | LG Studioworks 552V 15" CRT Monitor
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
