Question about Vacuums
How do i change the belt on the dc04 yellow dyson thx
devocap
  • 201 Answers
SOURCE: dyson vacuum cleaner DC04
I would suggest you invert the vacuum and remove the plate covering the spinning brush assembly. You should check the belt located on one side of the spinner brush to see if it is worn or broken. Also remove anything wrapped around the brush that could be affecting it. Ensure the brush is free to rotate and seated correctly. If the belt is worn or broken, or the spinner brush is unable to spin, replacements are available from a licenced repair facility. I hope it helps! Good Luck!
Posted on Jan 29, 2008
Agent Don
  • 310 Answers
SOURCE: brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Posted on Apr 15, 2008
grandadfixer
  • 99 Answers
SOURCE: why does my dyson dc04
thermal cut out in coils of motor,you have not been keeping filers clea,I THINK.
motor is avaliable
Posted on Oct 11, 2008
rustysheriff
  • 344 Answers
SOURCE: Dyson DC04 not working
Have you trod on the cable at all, sometimes the cable breaks inside the sheathing, test by switching on and wiggling cable where it enters machine, if it starts then thats your problem, easy to fix, disassemble switch, cut off and discard 6 inches of cable then reattach the reamaining.
Posted on May 29, 2009
ThinkVacuums
  • 144 Answers
SOURCE: DYSON DC04 how to remove switch housing to check
its most likely not the switch, check the power cord.. check where the cord meets to the vacuum. the cord could be going bad and most likely not a loose wire.
Posted on Sep 10, 2009
How to replace belts on dc04
Hi, it's Jeremy from Crucial Vacuum.
Attached in the link below you will find a how-to video on how to replace your Dyson DC 04's belt. The video will say DC 14, but be assured that they are compatible and the same method will work for your vacuum.
https://www.youtube.com/watch?v=7QpHz26KR5o
You can purchase direct your replacement Dyson DC04 belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc07-clutch-belt-set.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Dyson Vacuums
Dyson dc04 belt breaking
Is there something sticky stopping the brush from spinning freely will make the belt get hot and burn out
Jul 10, 2013 | Vacuums
How do I replace the belts on a Dyson DC04 purple
That model has a clutch unit from which the two drive belts are located. It is a technical job to strip that unit down to change the belts, so the easier solution if you have a snapped belt, is to replace the clutch unit (that comes with belts on it). A recycled one represents better value for money, and you can get one here: Dyson DC04 clutch unit.
Nov 07, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My belt has snaped on my dyson dc04 that has a clutch how do i change it
Remove the roller brush cover plate that is on the bottom and you will be able to access the belts. Here are the belts you need:
Dyson DC04 Belts
Nov 18, 2009 | Vacuums
Roller does not turn
It sounds as though you need to replace the drive belt. The necessary part is available from http://www.espares.co.uk/dyson/dc04/p/1086/716/4. Fitting it is tricky, but guidance is available from http://www.dysonmedic.com/DC04%20Folder/DC04%20belt%20change.html
Aug 02, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
I changing the belt
Not sure why you claim clutch belts cant be changed because they can.
The DC04 DC07 DC14 all use the same clutch unit if you cant get the belts from your local vac repair shop look on Ebay they are on there.
The special tools are torx screwdrivers & if replacing both belts you will require circlip pliers.
How to replace both belts in manual form can be found here http://dysonmanuals.llc.nu/index.htm
Sep 27, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brushes not going round
My dyson is a dc04
Apr 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
65 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
