Question about Honeywell Heating & Cooling
I had a Honeywell F4- 0019 motorised two port valve on my central heating that has failed. I have replaced it with a Honeywell valve from Thompsons Plumbase, but on fitting noticed the new valve has six wires instead of five, the extra wire being brown. How do I wire it in to get it to work which it doesn't if I ignore the brown wire. Thanks in hope Martin Fox
    Scholar:
  • 133 Answers
I'm doing a lot of guessing here for lack of information. You have a residential boiler and hydronic heating system that is zoned around your home and each zone has an independent thermostat?
Again, I need to guess. The old valve was spring return with yellow, blue and red wires? If all is true so far, then I think you had a single end switch with one COMMON - one NORMALLY OPEN and one NORMALLY CLOSED contact. 6 wires would make up 2 end switches. Brown is a normal color for one lead of an end switch. If this is all true, your new switches are probably NORMALLY OPEN and you only need 1. If this did not help you, give me a better description of old and new and I will get this correctly answered for you.
Posted on Apr 01, 2011
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Motorised valves
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Sep 27, 2012 | Cars & Trucks
I think my motorised valve is not working. I replaced the thermostat, have it down to 55 and there is still 70 plus temps in heat. system is 3 zones. i bought the replacement honeywell unit today. the...
I am having a similar problem mine will not shut down but what I understand from the service man is the valve should work on Automatic... manual is for a defective valve and you can force heat through by setting it on manual...
Jan 18, 2011 | Honeywell Heating & Cooling
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
My Honeywell 3 port valve in my CH/hot water systemis not working
Hi two things that go wrong inside the valve gets clogged up and blocks up in side, the valve in side and get worn sorry 3 things the motor on the top burns out , if you remove the top cover you will see a small motor with 2 orange wires on it you can remove the motor with 1 screw and see if its turning
Feb 08, 2010 | Honeywell Electronic Programmable...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
Central heating comming on,on it own
check motorised valve if you have one on the heating system
Jun 18, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Ariston micro genus combi boiler central heating works okay but domestic hotwater fails to rise but burners seem to be lit and the boiler doesnt appear to cycle dhw temp gets to about 30 degrees instead of...
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Dec 07, 2008 | Heating & Cooling
My boiler keeps firing up even when the Honey well programmer is in the off position. The programmer is about 7 years old.Do I need a new one, a new battery for it or is it to do with the boiler (oil)...
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
May 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
265 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
