Question about Brother XL-5340 Mechanical Sewing Machine
The needle holder came off the pin that holds the sewing foot in place. It appears a part is broken
  • 1 more comment
  • dancinfeet Oct 07, 2008
    I was sewing and the thing that holds the needle fell off. Seems silly that you tighten it, and when you sew it comes loose and falls off. In the process of trying to fix it... I lost the wire that is the 5th place to threading the needle. HELP!! I don't know of any sewing machine repairmen... I would hate to think I'd have to buy a new machine because of this, and Yes, I do have the manual but it's not a big help. It doesn't break it down for you.
    Thanks.. and I'd like an answer.
    Ramona Crabtree
  • lthill2001 Oct 27, 2008
    I was sewing several layers of fabric when I heard a "pop" and the wire that holds back the thread fell off. Then, after trying to sew again, the entire needle plus it's holder fell. I tried to put it back on, but it seems like it was only held up by lint and machine oil. I can't seem to see how it attaches other than by pressure. The black knob doesn't do anything but hold the needle itself from what I can see. Any ideas or suggestions?
  • stitchie Dec 23, 2008
    How and where does the last thread guide fit into the needle holder.
    stitchie
Not familiar with the XL-5340 but I have an XL-6562 - mine has done the same thing. There is a small black screw that requires an allen wrench to adjust. It is on the right hand side of the needle holder. Apparently it just works loose over time and with use. My son put the holder back on, adjusted that screw with an allen wrench and it has been fine. Not sure what to tell you though about the missing thread guide. Maybe it will be ok without that - I guess try it and see.
Posted on Oct 07, 2008
Thank you... that did help, but it won't sew as it should without the last thread guide. :(
Posted on Oct 08, 2008
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
"Check:
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
design
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
ok?
The feed dog must be lowered in embroidery
mode.
Jun 20, 2015 | PfaFF Creative 7570
PFAFF sewing machine: How do I attach the gathering foot on the PFAFF 1473?
usually a gathering foot or ruffler fits on like one would fit an old style foot. Unscrew the thumb screw that holds the snap on foot holder.... and place your foot making sure the needle holder thumb screw holds the lever on the other side. And tighten the thumb screw to hold on the foot.
Good luck.
Aug 02, 2012 | PfaFF Sewing Machines
Change needle?
If you are asking if you should change the needle, yes. My experience is that a dull needle will cause problems long before it breaks. If you are asking how to change the needle, then: first raise and then remove the foot (not really necessary but makes it easier) If possible do not remove the screw that secures the foot. Next loosen the small screw that secures the old/broken needle in place. Remove the old/broken needle, paying close attention to the needle's alignment (which direction is the flat side of the shaft facing) Insert the new needle with the same alignment as the old needle. Tighten the small securing screw, replace the foot and tighten the screw that holds it in place. Rotate the machine by hand to insure that the new needle does not strike or rub against anything during it's full cycle. Sometimes a broken needle will indicate a timing problem or a incorrectly installed bobbin holder. Re-thread the machine and check for proper operation.
May 16, 2011 | Euro-Pro Deluxe 7100 Mechanical Sewing...
How to sew buttonholes
First thing you'll need to do is switch the presser foot.
Your machine should have come with a specific button hole foot.
(might have an R on the bottom)
To snap off:
Raise the needle and presser foot.
Press the red button on the back of the foot holder
and the foot will drop.
To snap on:
Place the presser foot so the pin on the foot lies just
under the groove of the foot holder.
Lower the foot holder to lock the foot in place.
Select which buttonhole style you would like to stitch.
This can be done by selecting a mode (buttonholes are 06-08)
and then adjusting to the desired length and width.
After you do this, lower the presser foot and hold the foot pedal down.
The machine will automatically sew the buttonhole and stop when it is finished
All you'll need to do is just cut the thread after.
Hope you found this information helpful.
Mar 17, 2011 | Janome DC3050 Computerized Sewing Machine
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
Make sure it’s attached securely.
your needle.
Make sure it's securely in position.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
What instructions are there for a brother nx400 even-feed foot
Remove the screw holding the regular presser foot and the presser foot holder and set aside.
Place the take-up lever in the highest position.
Hold the even feed foot with your right hand with your thumb holding the lever of the foot in its highest position. Place the even feed foot on the presser bar and make sure that the lever of the foot rests upon the needle bar thumbscrew. While holding it in place, fasten the foot to the presser bar with the screw.
As the needle bar goes up and down, the lever on the even feed foot should rest on the needle bar needle serew and go up and down as well.
Jul 19, 2009 | Brother Sewing Machines
Brother XL-5340 Mechanical Sewing Machine Logo
488 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
