Question about Jandy AQUALINK RS TELELINK KIT
I just moved into a home with a Jandy AquaLink RS system. I shut off the power to the pool to replace a light bulb. To find out that the bulb was fine and the light was broken. When I turn the power back on, the pump/filter stopped working. Everything else worked (spa, waterfall). I took the motor to Leslie's and it worked fine. I tested the power of the circuit breaker and that was fine. There's no fuse to the RS system. What is wrong?
  • Diana Tran Apr 04, 2011
    Yes. Thank you.
    Sergeant:
  • 236 Answers
The circuit breaker likely has a ground-fault interrupter which is triggered by any current leaking to ground in the system. Resetting the breaker will cause it to be immediately triggered open again by the ground fault. You will need to isolate where the fault lies starting by disconnecting at the point closest to the breaker, checking for the presence of AC voltage at that point when the breaker is reset, then adding another segment and checking for AC voltage at the added segment. When you add the segment with the problem, you will find that resetting the breaker will cause it to trip again. If as you say that the bulb was fine but the light was broken, this would be a likely location for the ground fault as it was the only disturbance (you replaced the bulb with a new which also didn't work since the socket was broken) made to the system before turning the power back on (to the light) thereby causing the pump/filter to stop working (circuit breaker had just been tripped by the turning on of the light switch thus removing AC power to the entire system).
Posted on Apr 01, 2011
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
Solar has disappeared from my Jandy Aqualink RS control
go into system setup assign the solar to a aux it should work
Apr 10, 2014 | Jandy Aqualink Rs4 One Touch Control...
I have an Aqualink RS that will not turn the pool's filter pump on either by remote or in service mode
check your jandy valves make sure they are fully open or closed they can lock your system if they are not in full closed or open mode second option is to try to turn jandy valves manually to if they are in spa mode manaully change then to pool mode or if they are in pool mode change them to spa manually on the jandy valve there is a 3 way switch this is where you can turn them manually wt we want is to send the signal back to the main control outside that the valves are in ready mode look in the main control open the door and see if there is a red light that indicates another problem if you can send me where the red light is what the red light label says it will help if you send me the aqualink model #
Oct 06, 2013 | Standard Power Center for Aqualink Rs
I have a jandy AquaLink RS PDA screen that has Handheld 1.38 and ----Waiting----- on screen. Anyway to reboot?
shut everything off turn aqualink back on then turn on PDA if still doesnt make sure wire to antenna not cut
Mar 27, 2013 | Jandy PDA-PS8 Aqualink RS PDA PS8 Wireless...
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I am replastering my spa and want to put a new LED light in. Can I control the different light functions with th Aqualink and the button on the spa deck?
I have a Aqualink RS one touch control system, model 8157 RS6 Combo. The backlight in the control panal is out, the panal works fine, but does not light up, so it is hard to read. How can I replace the light? Do I have to replace the whole panal unit? Is there a bulb to replace? thanks, David
Feb 23, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink with IntelliFlo VS-3050
Jandy has an e pump.It would be cheaper to go that route.the Inteliflo is not compatible with the jandy system .If money is not a concern the pentair product is the way to go.
Sep 29, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have a jandy aqualink RS PDA. It will not
System locked up. Handheld is frozen at WAITING screen. Microprocessor is locked.
Here is what you do:
1. Turn off power to the system.
2. Disconnect battery at the Power Center and turn on power.
3. Reconnect the battery and reset time and date.
4. Thank me.... You are welcome... BadWally sends.
Jul 03, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
274 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
