Question about Dell E153FP 15" LCD Monitor
When I turn the monitor on, a message comes on indicating that the monitor is going into power save mode, then it goes blank and the power light turns yellow. How do I get the monitor to come on and stay on? Thanks...
    Guru:
  • 433 Answers
Dear \
1-adjust resolution to 1024x768
2- use original data cable
Posted on Apr 01, 2011
Power saving mode
Power saving modes are automatic for some LCD monitors some have setting like after 20 ,30 mins to an hour the computer monitor itself will go into standy saving modes like power led switch indication go to yellow led lighting or the monitor of the lcd screen go blank if ur computer have no pictures for displaying as a screen saver modes.Power saving modes it best for uses if ur computer it on all day long.If u don't touch the mouse or a keyboard the monitor will go in the power saving modes for less electricities consumption for less stress for the monitor electronic components for working to hard for the monitor not to malfuctions sooner or the monitor life cut too short because the computer it on all day.
Oct 12, 2012 | Computers & Internet
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
Viewsonic monitor stays on for only 3-5 minutes and goes off . Then I turn it off an wait and it comes back on!!! what is going on??
I guessing that when you say "goes off" you mean it goes into power-saving mode? Assuming that you're working on the computer at the time (so it's not actually going to power saving mode from inactivity), this might indicate one of two things:
a) the VGA cable to the computer is not in a good contact with the monitor. This might happen if you haven't used the screws to fix it in place, just try to plug it fully in on both ends (computer and monitor). If the monitor sees to VGA signal, it goes into power saving mode automatically.
b) there's a problem with the monitor that builds up after a few minutes. When you turn it off, it "cools down" and can be used again. If that's the case, you should take it to a dealer's shop and have it checked (or replaced if it's still under warranty).
Mar 13, 2011 | ViewSonic Computers & Internet
Just today when watching a movie my monitor will go blank and the light at the bottom which is white when on will go dark and then turn orange like it's been turned off then about 20-30 seconds later it...
When the power saving options of the computer is turned on, after particular time the signal stops to the monitor and the orange light will come on, once you move the mouse or press keys on the keyboard, the cpu comes back from the power saving mode, the signal passes on to the monitor and there will be display.
Sep 05, 2010 | Acer H233H bmid Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
