Question about Denon Audio Players & Recorders
I have a Denon PMA-880R Integrated Stereo Amplifier that has suddenly stopped working. One minute everything is fine, next nothing.
aparsons89
  • 40 Answers
SOURCE: An owners manual for a Denon AVR-2600 stereo amplifier
Hello, I found the exact web page for you to request your manual. Here is the link http://www.usa.denon.com/Product-Registration.asp Register your Receiver and then You can request the owner's manual, possibly in PDF format.
Posted on May 19, 2009
SOURCE: Denon PMA-520 amplifier clicking noise
Sounds to me like a bad capacitor, but not sure. I would look inside for any slightly bulging capacitors or capacitors whose plastic wrappings have melted or shrunk or cracked (most caps are cylindrical). Please unplug first and be careful inside there and do not touch anything. I actually came across your post while looking for info on what I think is the same amp my brothers had but blew, and I was going to ask if they still had it so I could repair it. I've been very successful at repairing my electronic equipment such as Altec Lansing Model 95 speaker crossovers, power supply in Emu Emax II, and almost everything else in my studio.
Posted on Oct 29, 2009
robotek
  • 1512 Answers
SOURCE: Operating Instructions, Denon PMA-535R/PMA-735R
Hi there
You can download one from here Select the FREE download button and you will get a PDF copy of the manual. Let me know if you have any problems getting it. Cheers
regards robotek
Posted on Jan 11, 2010
  • 88 Answers
SOURCE: SERVICE MANUAL FOR DENON PMA-495R
try abeltronics.co.uk
Posted on Feb 08, 2010
  • 88 Answers
SOURCE: Denon 528 amplifier cuts out after a few minutes
disconnect the speakers and see if amp will stay on. if this the case maybe suspect one of the o/p amps
Denon pma 355uk Amplifier manual required?
Try Googling (denon)(pma 355uk)(manual) without parens.
Jul 15, 2017 | Audio Players & Recorders
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
Cant get sound from my receiver and amp together
if you are hooking up 2 units to run together, take a pic of the back of both units, and post them here
Mar 06, 2013 | Denon Pma-520 Integrated Stereo Amp...
Hi, i have a Denon PMA 735 R amplifier which shuts down when volume increases suddenly.
Sounds like you have output transistor problems. Does it have a red protection light that comes on when it shuts down? If it does it will need serviced.
Dec 06, 2011 | Audio Players & Recorders
I have a Denon PMA 500V amplifier. all of the output fuses were blown so I replaced them but the unit still doesn't work. Any suggestions?
hi.
Did you checked balanced impedance?load speaker impedance vs PA output?or PA might over driven,causing a trouble on the pre-amp to power amp circuits and components damage,
need to recheck related components on the pre-driver up to main output section,
Note: That,blowing of fuses with the same rating is an indication of trouble/shorted in a circuits that driven on it,
Thanks and good luck
microhit
Jun 01, 2011 | Denon PMA-2000R 2-Channel Amplifier
My Denon PMA-900V integrated amp has distortion in the left channel. When it is cold it is very minor, as it heats up and is played at louder volume the distortion is much worse.
The good news is that it's in one channel, which means you have the right channel parts to compare it with. Now the bad news whatever causing it and it's likely to be a semi-conductor (transistor or IC) has to be replaced. However finding it is easier than you might think. For a start it's going to be hot to touch. And you can get get it to stop being hot, while the amps on, so correcting the fault, for a while. You do this by spraying it with Servisol Super Freezer spray. You have to have the amp running for this. Find the left channel amp and wait while it goes bad. Then spray (one at a time) any part you suspect. If the sound returns to normal, you have found the faulty part! To prove it spray the same in the right channel. That shouldn't change.
You can get the freezer spray from your local electric parts shop (such as Maplin UK).
Jan 13, 2011 | Denon PMA-100M Amplifier
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Denon PMA-100M Amplifier
DENON Input selector jumps randomly
I have a PMA-535R. Same problem but slightly different dialknob. I fixed it by spraying a contactspray and WD-40 into the knob itself. This does mean you have to disassemble the front of the amp and take out print of the dialknob. The knob has a plastic dustcovere that you will have to lift. Good luck
Sep 18, 2008 | Audio Players & Recorders
291 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
