Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
My tv keeps turning off and on. What shall I do?
  • jbsatty Apr 01, 2011
    Thanks!
  • Sony Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 01, 2011
  • Walesarumi
    Walesarumi Apr 01, 2011
    You are welcome! Thank you too for using Fixya.
My 2006 Jeep Liberty won't start or turn over all I keep hearing is this click sound when I turn the ignition , Plus I just replaced the battery........What shall I check next?
check your starter,better yet has your alarm system been activated and possibly shut down your car a passive alarm will do that
Mar 27, 2012 | 2006 Jeep Liberty Limited
What picture mode shall I keep to view normal picture? At present it is on "full" mode but the picture is zoomed
Choose JUST or 16:9 mode . Some TV's don't have it labeled JUST. It means the TV will follow the input signal and adjust the picture automatically.
Apr 29, 2011 | JVC Televison & Video
Tv wont turn on green timer light keeps flashing i have left it off one week,all day then try again,still nothing.shall i toff the tv,is it worth fixing?
I dont know for sure but i got a hdtv someone threw away and was doing the same thing and i popped off the back and right where the power cord goes in there was a blown fuse. Which i bought at radio shack for like thirty cents. That was like nine months ago and still works good.
Aug 23, 2009 | Televison & Video
I have a sony wega kdf e55a20 that keep on shutting on and off
Lamp is weak and TV needs new lamp.
Please buy original Sony Lamp for better performance of TV.
Jan 19, 2009 | Sony KDF-E55A20 55 in. LCD Television
My nokia 2600 keeps on reseting when turned on
This the problem with the corrupted phone software. Get it reinstalled from local phone service center it fix the issue.........
May 30, 2008 | Nokia 2600
Plasma tv th-50px600a
I turned off the set.It was off for about4 hours.I simply turned (using hand controls) the set back on. Up came the picture.
It can't be fixed.I shall keep records to try to build up a picture of what is happening.I think I'am in for a crappy few months.
Neil Brazel
Apr 07, 2008 | Panasonic 50 in. Plasma TV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
171 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
