Question about Dryers
Inside the drum, there are three "panels" attached to to the wall of the drum. I guess they are used to tumble the clothes so the heat is evenly exchanged? One of the panels broke off. There are no screws, but two or three holes remainig. Perhaps they were plastic and wore out or the screws fell in behing the drum? Do I need to be concerned since this is a gas dryer (for safety reasons) if the dryer still works. It is 10 years old and I don't know whether it is worth fixing. Heavy loads never dry completely the first time around, and often require an additional 20 minutes drying time. Thanks!
  • 4,059 Answers
It wont hurt anything to use it like that. The screws probably fell outside the drum when they came loose. You can look at the other two to see how they are fastened if you want to put it back on.
Posted on Apr 01, 2011
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Plastic things inside the drum have all come off,
If they have come off, it is because they are worn or broken.You need to fit 3 new ones
They are referred to as drum or clothes lifters, thier purpose being to move the clothes around.
Do not use the washer until you have got them fitted.
They usually slide and click into the slots in the drum.
Mar 01, 2010 | Indesit Washing Machines
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Does not spin/tumble
sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
May 31, 2009 | Dryers
Dryer drum won't spin/tumble clothes
Chances are it's a broken belt. If you hear the sound of the motor running and your dryer is heating, there's nothing else but the belt.
Changing the belt yourself is pretty easy if you can use a screwdriver and have a little mechanical ability. The new belt is around $20, and you'll save big if you don't call a service person to do it for you. A good site with a step-by-step illustrated procedure for changing the belt is here. They also sell parts, or you can find the belt locally at any appliance parts store.
May 04, 2009 | Dryers
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
