Question about LG LRSC26930TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Icebeam Cooling & OptiChill Drawer: Tit...
LG Model GR-B218JUDA - The bottom door has come off the brackets - How can I get it back on?
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
  • 1891 Answers
SOURCE: I have a old unit
you can see the schematic at slect-parts.com / you will need a complete model # . mm
Posted on Aug 10, 2010
geterrollin
  • 277 Answers
SOURCE: have an LG
is it ice build up inside the back? try dfrosting the fridge and see if that helps
Posted on Jan 18, 2011
heatman101
  • 43501 Answers
SOURCE: model no. GR-B218JUDA.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 01, 2011
GE model ddt575ssf0ss door reattachemnt
The door may not have been correctly reinstalled on the bracket.
Jul 26, 2016 | GE Refrigerators
LG B218JUDA fridge freezer, the fridge compartment has started freezing food. I've checked temp buttons at 3 and made sure air vents clear
there are more warmer settings . but it could possible the air control has stuck open too far also
Jul 01, 2015 | LG Refrigerators
How do you change the direction of the door opening.
(THIS IS A TWO PERSON JOB)(be sure u unload the door first)At the top of the door u have a bracket with three screws or bolts in it, take out the screws while the other person holds the door once this is done take off top bracket the door should lift off of the bottom bracket,now take the bracket off the bottom of the refrigerator,On the other side of the fridge there should be some small white plastic plugs pull them out ,this is were u will put the bottom bracket ,u will also have some plugs on the top of the fridge too..be sure u put the plugs back in the holes that u just took the screws out of.Put the bottom bracket on first,do not over tighten screws,then take ur door place the bottom of door on bottom bracket,put bracket for top of door in the top and screw back down now ur door should be good make sure it closes correctly,and of course put the stuff back in the fridge
Mar 31, 2011 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
LG GR-349R bottom mount freezer gets heavy ice build up in 3-4 days under lower drawer in freezer. L side of fridge near where fridge and freezer doors meet is very warm to touch.
Find the drain tube in the back and check it for a frozen state. If it si,use a hair dryer to thaw it. If it does it again, you have a defrost problem
Jan 10, 2010 | LG Refrigerators
Could you please tell me if replacement doors are available for my LG Bottom Freezer Refrigerator Model No GR-F258JTT . I am living in Perth WA , and if so what would the cost be and who could do the...
look in the yellow pages under large appliance repair. You should be able to find a tech. who can get LG parts and can replace your door or door skin. You will have to get an estimate, or ideally three estimates so you know you are not getting taken to the cleaner. good luck.
Sep 12, 2009 | Freezers
My frige has two handles, and the bottom handle for the frige was loose and came of, how can i get a new handle for my frige. Its a LG Model GR-642QVP Serial No REFER BAR CODE LABEL A.3850JZ0373A
Sounds like you have a UK model LG refrigerator. Go to www.lge.com and from there you can select your region and get the phone numbers to call the UK LG Parts Dept. to purchase a new handle. Hope this helps.
P.S. I work for LG!
May 27, 2008 | LG Refrigerators
LG LRSC26930TT 36" 25.5 Cu. Ft. Side-by-Side Refrigerator w/ Icebeam Cooling & OptiChill Drawer: Tit... Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
