My rca L32wd22 tv won't turn on it is shows a solid amber light. What can I do to fix it?
  • 6,993 Answers
First, remove it from the wall plug, fix it back in and try again. If that doesn't work, it means there is a problem, read further.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 01, 2011
  • Back2life Electronics Jun 07, 2011
    I don't know if you fixed your problem or not but I had the exact same thing. I repaired it myself for around $15. The chopper mosfet for the 24v/15v circuit was shorted. It took out the PWM controller, 450v 1000uf cap, and fuse. I replaced those and walaaaaaa. If you need a schematic, drop me an email, will gladly share it. Back2lifeElectronics@gmail.com
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
Tv LCD RCA model L32WD22 what ic replacement can I use?
servicios,
Close the the unit up as you had before opening. Take the unit to a service centre and have them fix it. They don't have manuals to repair so, when they say, "We can't fix this" you take the work order and call1877-297-8391 and they will get you a new tv
Mar 17, 2010 | RCA L32WD22 32 in. LCD HDTV
RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Mar 10, 2010 | RCA L32WD22 32 in. LCD HDTV
My L32WD22 doesn't seem to be getting any power.
tnbanderson,
Pls take your tv to a tv service center and ask them to fix it. They won't be able to. So you make sure the make a workorder. When you get that order, you call 1-877-297-8391 and they will give you a tv
Feb 03, 2010 | RCA L32WD22 32 in. LCD HDTV
I have a rca l32wd22 screen weht black with no
Aboyd992,
Take your tv to a service center and ask them to fix it. If they cant...
Have them make out a work order and then you call 1-877-297-8391. The people at the other end ot the tele number will give another tv
Jan 09, 2010 | RCA L32WD22 32 in. LCD HDTV
I have an rca tv and vertical lines show up when i power the tv on model # is L32WD22
Tumble9827
Pls take your Tv to a Service Centre nrear you. Ask them to repair, and if they say they can't... Get that in writting on a Work Order,
Then call 1-877-297-8391
Dec 24, 2009 | RCA L32WD22 32 in. LCD HDTV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Jun 01, 2009 | RCA L32HD31 32 in. LCD HDTV
Televison & Video Logo
424 people viewed this question
Top Televison & Video Experts
Electro Med Services...
