Question about Polycom SoundPoint IP 501 IP Phone
Purchased refurbished phones and they do not have the Factory Defaulted Admin Password. How to reset the Polycom Soundpoint IP501 to Factory Default Admin Password?!?
    Scholar:
  • 82 Answers
The factory Admin info is Polycom for the user and 456 for the password. If the password has been changed, you can do a factory reset by holding down 4 keys until it restarts. The four keys are * 4 6 8.
Posted on Jun 16, 2011
    New Friend:
To reset to factory default settings.
1. remove the power cable from the phone
2. press and hold down the * key, then put the power cable back in
3. let go off the * key
4. press # 5 * 5
5. the phone will revert to its factory default settings
The administrator password to login to the phone's web-configuration page will have reverted to one of the following default admin passwords:
1234
12345678
09160723
[blank]
note: For the [blank] password, just press the 'login' button when nothing is typed in the password box.
On firmware version 1.36, if the "iptype" setting is set to the "modem" option, the phone will crash at bootup, showing "Booting.." on the LCD display. To fix this, you will have to boot the phone in safe-mode, and change the iptype setting out of 'modem'. To do this...
1.Unplug the power and Press " * " and then plug in the power while you holding the " *" key. When you see it show " * " at the G668 LCD screen, disconnect the power.
2.Repeat Step 1.
3.Then, while the power is turned off, press and hold the "#" key and then plug the power again.
4.The G668 LCD screen should show "Password", please key in "1234", then the "speaker -free button"
5.The screen will go to "network settings", please press "speaker -free button", and then it will show "iptype 3[modem]" or whatever in your setting.
6.Press "Local IP", the "iptype 3[modem]" will become "iptype _" (the underscore is the cursor)
7.Press "1" for dhcp or "0" for static ip (recommended to press "1" for DHCP for now) and then press "Redial button" three times to the "save settings" and then press "speaker-free buttorn"
8.The screen will show "save Are you sure?", please press "speaker-free buttorn" again. G668 will reboot and work normally.
Posted on Jun 29, 2017
On Polycom 335 how do I reset voicemail for new employee
"If you need to remove the resource files from a phone at some later date-for example, you are giving the phone to a new user-instructions on how to put the phone into the factory default state can be found in 'Quick Tip 18298: Resetting and Rebooting SoundPoint IP, SoundStation IP, and Polycom VVX 1500 Phones' at http://support.polycom.com/global/documents/support/technical/products/voice/SoundPointIP_Resetting_Log_Files_QT18298.pdf "
http://supportdocs.polycom.com/PolycomService/support/global/documents/support/setup_maintenance/products/voice/spip_ssip_vvx_Admin_Guide_SIP_3_2_2_eng.pdf
Oct 06, 2014 | Polycom SoundPoint IP 320 SIP IP Phone
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
Can ping my polycom 501 but cannot open with my
Have you tried a factory reset from the menu interface? Be careful if you do, and only choose "Format File System" as a last resort, and only if you feel comfortable enough setting up a FTP/TFTP boot server to re-provision the phone, as this option will erase everything, and then all it'll do is get stuck in a boot cycle until reprovisioned.
Feb 22, 2010 | Polycom SoundPoint IP 501 IP Phone
Have a Polycom Soundpoint IP501 SIP phone. Some of the #s on the keypad do not work. Can I replace the keypad myself?
I would not recommend that. The keyboard circuit board is fragile to someone taking it apart for the first time.
Dec 30, 2009 | Polycom SoundPoint IP 501 IP Phone
What is the default password for Polycom Soundpoint IP 320 SIP?
Default Passwords:
To get into the web interface, the default username/password is "Polycom"/"456" (Note that this does not work with Safari 1.2.2.)
To get into the Admin interface on the hard phone, the password is "456". (Prior to v1.3.1, the web interfaces to the phone uses "Polycom"/"SpIp" as the username/password.)
The "user password" (not used much) defaults to "123".
To reset a lost admin password to default: at phone boot, during the 5 second countdown, push/hold 468* on the phone. Enter the phone's MAC address as the password. This will reset network info but keep peers loaded. Tested on Soundpoint IP 650.
Dec 22, 2009 | Polycom SoundPoint IP 320 SIP IP Phone
Reset password
Plug the phone in and allow it to boot up. Once the home screen is displayed, press and hold the 4, 6, 8, and * keys for about three seconds, or until you hear an audio alert and the phone asks you for a password. Enter 456 (default Admin password) and the phone will default itself. If the password has been changed, and 456 does not work, enter the MAC address of the phone as the password. Entering the MAC address of the phone will only reset the Admin password to the default, so it will probably be necessary to repeat this procedure, entering 456 the second time, to factory default the phone.
Dec 04, 2009 | Polycom SoundPoint IP 550 IP Phone
Can you help me i need username and password for a 330
Did you try the manual on Polycom's website?
SIP Admin Guide:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
If you really need it spelled out for you, your answer is on page 4-99
May 28, 2009 | Polycom SoundPoint 330 IP Phone
How to reset VSX 8000 to factory default - Forgot the password
RTFM!!!
section 8, page 4
System -> Diagnostics -> Reset system
you will need serial number for this
good luck.
May 03, 2009 | Polycom (VSX 8000/VORTEX EF2280 ) (Bundle)...
Polycom SoundPoint IP 501 IP Phone Logo
4,052 people viewed this question
Top Polycom Computers & Internet Experts
Darren  Means
Darren Means
Jack Frost
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
