Question about Pioneer PDP-507XD 50 in. Plasma Television
We cannot switch on our Pioneer PDP-507XD. The light at the front of the TV just blinks
  • Pioneer Master
  • 6,993 Answers
First, remove the TV plug from the wall, fix it back in and try again. If that doesn't solve the problem, then it means your TV is having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 01, 2011
Pioneer PDP-R04U receiver blinking Help!?!
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 28, 2013 | Pioneer PDP-4350HD 43 in. Plasma...
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
We have had problems switching on our Pioneer PDP-507XD plasma tv. The standby light just flashes. We were advised to change the power supply unit. We hav4e done this and it has not solved the problem ...
I've been running across a lot of plasma tvs where the power supplies are not bad, but the X & Y-sustain boards are faulty. My advice is to change those boards out as they are responcible for lighting the plasma gasses in the tv. You can attempt to replace one at a time (cost reasons), but it is recommended to changed both at once.
Hope this helps, please rate. :)
Apr 11, 2011 | Pioneer PDP-507XD 50 in. Plasma Television
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
I have a Pioneer pdp-433 plasma with a media receiver pdp-ro3e. When switching it on it gave a loud pop and blew up a fuse in the meter cupboard. Now when switching it on it gives green light on receiver...
Alas, the powerblock has gone.
Common problem on this model.
Only solution is replacement powerblock.
Pioneer used to repair this for nothing even out of warranty (they did for me), but they may not be so willing now, as your tele must be at least 6 years old. Unfortunately, it will be cheaper to buy a new TV than to pay for a contractor to fix it.
Brian
Jul 13, 2009 | Pioneer PureVision PDP-4330HD 43 in....
Pioneer PDP-507XD 50 in. Plasma Television Logo
215 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
