Question about Ubi Soft Prince of Persia: The Forgotten Sands - Windows
Hello, There is a problem with my pop forgotten sands, In the level of Palace, when i use a pressure plate and door will open up and once we enter the door, a cut scene appears where three summoners will be summoning sand soldiers, but the door that i came through never closes, and the once i get to the top side where summoners are. The door never opens even though i reached there by hanging on to the pole, that is supposed to open the door to proceed. I need help for this because i a struck here
5 Suggested Answers
  • 6 Answers
SOURCE: i want know prince of
http://www.playground.ru/cheats/42268/
Posted on Jun 05, 2011
  • 11 Answers
SOURCE: i am not able to
Does the error say that the dll is missing? Then it's simply a case of installing the required dll onto your PC. For a good guide which shows you how to find the required dll then install it, go to http://www.makeuseof.com/tag/how-to-fix-missing-dll-file-errors/
Posted on Aug 17, 2010
SOURCE: please give me a username
i need a password
Posted on Apr 07, 2011
  • 5 Answers
SOURCE: i was asked for ubi
you can go to ubisoft (site) and make a new one, be sure that if you have vista or windows 7, that your firewall don't block it and you run it as administrator. anyway, you don't need to log in, you can skip it, there is a skip button i thought.
___
im new :D
Posted on Sep 23, 2011
I want to move my fridge but it's locked in place. How to unlock?
Hello Tina;
My name is Peter. I am a retired field service refrigeration technician.
You did not post your model number which is located on a label on the inside liner wall of your fresh food section.
First remove the bottom grill or toe plate in front of your refrigerator. This plastic piece is either held on with one screw at each end or pop out clips. If clips pull the plate straight out about 2" from each end. This plate is easier to remove with both doors open.
Refrigerator Leveling Screws: Most refrigerators have two leveling screws in the front, one on each side. These screws are for leveling the refrigerator from rolling on the wheels. Turn these screws counter clockwise.
Refrigerator Wheel Locks: Some refrigerators have a lever bar on the outside of the front wheels to lock the wheels in place.
Refrigerator Independent Wheel adjustment Screws: Some refrigerators have two hex head screws on each side. They raise and lower both the front and back wheels.
Mar 04, 2016 | Refrigerators
My lg dishwashers door will drop open suddenly
If it is sudden opening during cycle then it is due to pressure build up inside the dishwasher is forcing the door to open.
a) Most likely your door latch is not holding proper enough. Quite common on LG.
b) May be your vent in the dishwasher is blocked so the pressure inside cannot get out. If vent blocked you have plate drying problems too.
c) Is the dishwasher leveled properly. Is it leaning to the front. This will be that extra help for the door to open when pressure build up inside the dishwasher.
Sep 26, 2014 | LG LDF6810 Built-in Dishwasher
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
Aug 14, 2014 | Meiko FV 40.2 Dishwasher
I have a brand new side by side GE GLS 25 when you close the refrigerator door the freezer door pops open and stays open. i tried adjusting the doors, nothing works
The fridge is not leveled. If you remove the kick plate in the front you will noticed that oven each of the front leg there is a mechanism to level it.
Mar 14, 2011 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
Hello. My washer seems to be filling up with too much water. It is draining during the draining cycles but fills up with so much water that it is above the window and starts coming out the soap drawer. ...
Sounds like you water level switch is bad.
Without model # I can't research the part # but if you open the lid there will be a metal plate with a model # xxx.xxxxxx go to www.sears.com and select "parts direct" under the sevice drop down and enter the model # where indicated.
You will get a page with exploded views of the washer and a list of part#s
Jan 08, 2011 | Kenmore Washing Machines
The dishwasher door keeps popping open
I have the same problem and it appears that everyone else who has replaced the door seal runs in top this issue. This is a new seal design that is different from the original. This new seal is obviously poorly designed is placing too much pressure on the door causing it to either not close, or open mid cycle. I am presently duck taping the door closed when running the machine in the hope that the heat cycling the new seal will eventually cause it to deform and relieve the pressure. I see that other have attempted to help the process by increasing the release pressure on the latch. This will be the last Kitchenaid large appliance I purchase.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Blue switch palace
the blue switch palace is on the second way out of the forest of illusion 2 level
Aug 30, 2008 | Nintendo Super Mario World: Super Mario...
GE TFX22R side by side door problem
Undo the bolt at the bottom of the fridge side and have someone hold the door level, this happened to mine over time and the doors had just became uneven. Level up both doors by refixing the bolts and see if that helps. It did for me.
May 14, 2008 | Maytag MSD2756G Side by Side Refrigerator
Ubi Soft Prince of Persia: The Forgotten Sands - Windows Logo
115 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
dante
Tom Chichester
MegaByteMe
MegaByteMe
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
