Question about Buffalo Technology TeraStation Pro TS-1.0TGL/R5 (TS10TGLR5) 250 GB Network Hard Drive
I need to reset the IP address, subnet, etc, of my TeraStation 1.0TGL/R5, but I cant do with the nav tool on the computer. Is there any way to manually reset it? Thank You
  • 656 Answers
Click start run and type in cmd click ok when ms dos prompt up in that type ipconfig /renew then you will see the renewed ip address subnet mask etc
Posted on Apr 01, 2011
I just configured my MFC 490cw for wireless printing. It works but now I have IP address conflicts across all computers XP & Windows 7) and X-box in the house. If I turn the printer off, the network...
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
(see the owners manual or site for steps on configuraing the printer TCP/IP information). This should take care of any conflicts.
Jan 29, 2011 | Brother MFC 490cw Color Inkjet...
Tip
How to Calculate an IP v4 Subnet
An IP address is a specific address assigned to a computer across a network, allowing computers to communicate with one another. When IP Version 4 debuted, there were far less computers on the web. IP v4 only contains 4,294,967,296 possible addresses, including subnet number and broadcast addresses. Now, there are many more devices on the web and because of this, subnetting (as well as NAT) was developed as a way of maximizing usable addresses.
The Parts of an IP Address:
IP addresses contain 4 octets, 8 bits each. For example,
192.168.1.1 in binary is
11000000.10101000.00000001.00000001
The Mask:
A Subnet Mask tells a computer what part of the address declares a subnet so it knows when the destination address is on the same network or needs to be routed to a different one. For example,
The subnet mask 255.255.255.0 in binary is
11111111.11111111.11111111.00000000
when applied to 192.168.1.1 or
The first 24 bits are the subnet. So, all addresses in 192.168.1.xxx are part of the same subnet. When a computer with address 192.168.1.2 wants to communicate with a computer with address 192.168.1.3 The information does not need to be routed because the computers are on the same network. However when a computer with address 192.168.1.2 wants to communicate with microsoft.com or 207.46.232.182, the data must be sent to the default gateway to be routed.
The area that is not covered by the mask (in this case, the last octet) are used by the network. The lowest possible number of .00000000 or 192.168.1.0 is the subnet number and the highest possible number of .11111111 or 192.168.1.255 is the broadcast address. These particular addresses cannot be issued to devices on a network. This leaves 254 addresses on 192.168.1.0 that can be assigned to devices on that network. The default gateway (the router) can be assigned any address in that space. However, it is typically assigned the first address (192.168.1.1 in this case)
One more example:
Ip address of 10.101.75.150 with subnet mask of 255.255.252.0 or,
IP:00001010.01100101.01001011.10010110
SM:11111111.11111111.11111100.000000000
00001010.01100101.010010 00.00000000 or 10.101.72.0 is the lowest address (aka subnet number) and
00001010.01100101.010010 11.11111111 or 10.101.75.255 is the highest number (aka broadcast address)
Any number in between is assignable to a device on the network.
The Easy Way (without binary):
Always look or the odd octet (the one that isn't 255 or 0) in the subnet mask.
255.255.252.000
in this case is 252. Subtract that number from 255 and you have 3 (or as I like to call it the magic number)
find the same octet from the IP address:
010.101.075.150
255.255.252.000
in this case is 75. Find the multiples of the magic number that this octet is between. In this case, 75 is a multiple of 3, so the numbers we are looking for would be 75 and the previous multiple 73.
So far we have,
10.101.73.xxx and
10.101.75.xxx
fill the X's for the low number with 0 and
fill the X's for the high number with 255 and you have,
10.101.73.0 (subnet number) and
10.101.75.255 (broadcast address)
All addresses in between are usable. As confusing as it all may sound, all takes is practice. "Practice makes perfect." Try making up your own IP address and Subnet mask and calculate the range to find the subnet number and broadcast address. In time you will have it down to a science.
on Nov 05, 2010 | Computers & Internet
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Sep 28, 2010 | Computers & Internet
My computer can not find my new wireless printer. the printer said it is connencted to the the right SSID and the printer software is downloaded but they cant find each other. Also when i look in to my...
Check the Lan/Wlan settings on the printer. Set to DHCP for address and reboot the printer. This should ensure the machine is getting it's IP address from your router. Recheck the IP address and subnet mask are in the same range as your computer and router and try a test print. If that does not work - manually set an address in the printer with a terminal value of 50 eg 192.168.0.50. Try that. If still no good, reset the printer IP to DHCP automatic and reboot the entire system. Please note if you are using Apple/Mac portable computers - your IP address range may change every time you boot in a different location.
Nov 15, 2017 | Canon PIXMA MP530 All-In-One InkJet...
Hello I'm trying to connect a Buffalo terastation(storage media) through the internet so that they can store files on it. I have no problem accessing it from anywhere except through a server that passes...
I'm guessing that you have a routing issue caused by the address of your tera server not being on the right subnet. Typically, addresses like 192.168.1.10 will have a subnet mask of 255.255.255.0 which will cause problems when you have a statically assigned ip of 222.222.222.222. You would be best off to assign your teraserver within the 192.168.1.x range, but outside of the range dynamically assigned by the router. Typically, you can control which addresses are assigned by the router (say 192.168.1.50 - 192.168.1.100). Just make sure that the tera server is outside this range so that it does not duplicate another device. Make it something like 192.168.1.11 or 192.168.1.222.
Hope this helps - flub
Jun 01, 2009 | Computers & Internet
New Fan for buffalo terastation ts-1.0tgl/r5
just the fan, with 3 wires, as long as it has the 3 wires then you can adjust the speed... most fans do come with this 3 wires setup now adays
Apr 15, 2009 | Buffalo Technology TeraStation Home...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Buffallo terastation
How can you loose the password? if your that stoopid then i think you shouldnt own TS,or is it you have bought second hand only to find its password encrypted? either way if you cant read then you shouldnt own a TS instead why not see if you can swap for an external HD ;D
Jan 25, 2009 | Buffalo Technology TeraStation Home...
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Buffalo Technology TeraStation Pro TS-1.0TGL/R5 (TS10TGLR5) 250 GB Network Hard Drive Logo
863 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
