Question about Brother MFC 420CN All-In-One InkJet Printer
Upon power on machine says unable to init - Brother MFC 420CN All-In-One InkJet Printer
  • Brother Master
  • 379 Answers
"Unable to init" is caused by a problem with the carriage (the mechanism that holds the print head and moves it across the paper) causing it not to move. This could be something as simple as a foreign object getting in to the printer and obstructing the carriage, but unfortunately is more commonly failure of the carriage motor itself, or the electronics that control the motor. The user manual for your machine (available from the Brother website if you've lost it) will show you how to check for obstructions - basically lift the upper part of the machine up (not just the scanner lid but the part you need to lift to access the printer/network cable connection) and check the rectangular opening you can see.
If it isn't a simple obstruction, then I'm afraid there is no simple solution to this problem.
Dismantling these machines isn't staright forward and parts are very difficult to obtain and very, very expensive, so much so that 99 times out of a 100, it isn't cost effective to repair.
You could approach a Brother service agent, but it's highly probably that they will charge you more than buying an equivalent brand new machine.
Sorry.
Posted on Apr 02, 2011
2 Suggested Answers
  • 60 Answers
SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Posted on Feb 03, 2010
How to clear "unable to init.73" in brother dcp-j125 printer?
Hi
This is a mechanical problem of some description. Open the scanner cover and remove any foreign objects and paper scraps from inside the machine. Then, disconnect the machine from the power for several minutes and reconnect it. This should clear the error, but if it does not repeat the procedure making absolutely certain there is nothing in the printer obstructing the paper path.
You can get a manual for this machine here:
http://data.manualslib.com/pdf2/36/3557/355673-brother/dcpj125.pdf?5f68814c3d046699f5763ce9725a25e1
and there is a manual resetting procedure that you might try here:
Reset Methods for All Brother Printer Models
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
How can I fix DCP-195C unable to Init 4F?
Could be print head or print head PCB problem .
Sep 06, 2014 | Brother DCP-195C A4 Colour Inkjet...
Unable to init 4f
Problem with Brother DCP-J125
Unable to init 4f
Aug 06, 2013 | Brother DCP-J125
Dcp unable init
I have got an error "Unable to Print 48"
May 15, 2013 | Brother DCP-J125
Brother DCP-115C printer unable to init.
Here's what the manual states in the troubleshooting section:
Unable to Change
Unable to Clean
Unable to Init
Unable to Print
Unable to Scan
The machine has a mechanical problem.
-OR-
A foreign obstacle such as a clip or ripped
paper is in the machine.
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
Check the Brother website here:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000500/000065/faq000565_001.html?reg=eu&c=gb&lang=en&prod=dcp115c_eu_as&Cat=11
Sep 02, 2012 | Brother DCP 115C All-In-One InkJet Printer
My brother j220 displaying unable to init.49 how can i remove it
The machine has either a mechanical problem or there is something in the machine such as a paper clip or scrap paper.
open up machine and inspect it. use compressed air if needed to clean everything out. If this does not work then unplug for 5 minutes and then re-power on and see if it comes back if so you will need service on it.
here you will find user guide to further assist
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_J220_J265w_J410w_EN_2577.PDF
Jul 12, 2012 | Brother Office Equipment & Supplies
My brother all in one printer givin init unable 49
Init Unable XX:
problem.
-OR-
A foreign object such as a clip or
ripped paper is in the machine
Open the cover and look inside the
machine for foreign objects and paper scraps.
for several minutes, then reconnect it.
If it does not clear, you may need service:
In USA: 1-877-BROTHER (1-877-276-8437)
1-901-379-1215 (fax)
In Canada: 1-877-BROTHER
(514) 685-4898 (fax)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Office Equipment & Supplies
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Error code: init unable 51
It sounds like a switch actuator is stuck down by a piece of paper in document feeder..
Unplug power cord for 10 seconds
Jul 26, 2008 | Brother IntelliFAX 1840C Plain Paper...
Brother MFC 420CN All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
