I have my Dell 1600N printer plugged into a Telus Internet Hub, however I can not print to thiis printer with my laptop (Windows 7). When I go to Devices & Printers on my laptop, and click on the printer icon, the printer says Offline. Any ideas?
  • 24 Answers
Go to control panel -->Printers --->Right click on the printer icon and select "Use Printer Online". Then try printing
Posted on Apr 01, 2011
All functions work on my 1600n printer with the exception of the scanner. The workstation names that normally appear when a doc is scanned do not appear
The Dell 1600n requires that the Dell Network Scan Manager is running. Windows Vista and Windows 7 require user level authorization for this app to run properly and may be prompting you at start up. If you are telling it "no" when propmted then this is one thing that can be hanging you up. It is also possible the app is simply not running at all. Go to start>programs>Dell>Network Scan and see if it picks it up then. This app is how the dell printer itself gets the names to put in the list of available workstations to scan to.
Jul 26, 2011 | Dell 1600n All-In-One Laser Printer
Document failed to print" message
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Jan 18, 2018 | Dell 1600n All-In-One Laser Printer
I have Dell 1600n and run Windows Vista 32-bit. Whenever I print, I have to manually clear the print que. How do I have the print que automatically cleared after every print?
Go to the printer properties and untick print que and select print directly t o printer option.Alternatively download the rpcs drivers instead.
Jun 25, 2009 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
Print Error - New HP Presario A900 Laptop
hmmm...ok...so do you have the correct Dell drivers for Vista installed?
support.dell.com has those by model number
Aug 01, 2008 | Dell 1600n All-In-One Laser Printer
Have a Gateway laptop with Windows XP. Want to use Dell 1600n printer
Download the drive from Dell, and run it to unzip it. When adding the printer, click "Have Disk" and point it to the folder that you downloaded the driver to.
Jun 19, 2008 | Dell 1600n All-In-One Laser Printer
Windows Vista can't find networkd Dell 1600n
Make sure you're using the drivers for Vista, which can be found on support.dell.com. You'll want to use the choice for Vista 32-bit.
Also, try turning off your firewall, as it may be blocking the network data.
Dec 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
35 people viewed this question
k24674
jasbo
jasbo
