Question about Kitchen Ranges
Have an electrolux ergospace vacum xxl cordmatic 1600w it's just been stop working ,I plug into power point no sign of life it's dead it's been one year old is it repairable or throw it thks guys
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic 1100W high power
It may have a blown fuse or - assuming yours is a model NN-H965 - a defective inverter. The fuse is generally located on the bottom of the chassis of the microwave. You have to remove the outer cover on a counter top model - or the front panel assembly on an over-the-range model. There are several reasons why it may blow. If the fuse is loose in the holder, the fuse and the holder should both be replaced. If - with the microwave disconnected from the wall - you can easily turn the fuse with your fingers while it's in the holder, then it's too loose. What happens is the loose connection generates too much heat, causing it to melt internally. If so, you'll usually see a ball of solder at a point where the cap meets the body of the fuse. If the fuse blows as soon as you plug the oven in the wall, or when you open the door, the problem is likely with the door switches. You can find my files "doorsw.txt" and "safety'txt" via Google. They give you the safety warnings and cover the diagnosis and replacement of the door switches. If the fuse blows as soon as you hit START, then it's likely that you have a shorted high-voltage capacitor. If the fuse blows a few seconds after you hit START, then it's likely that you have an overheating / shorting high-voltage transformer. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. They offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number. Be safe!
Posted on Oct 14, 2006
  • 3 Answers
SOURCE: Vacum cleaner flashes lights and goes dead.
Do you put it down before you turn it on? some vacs wont turn on in the upright position. Happened to me once til I stepped on the button to bed it back then powered right up.
Posted on Jan 15, 2010
  • 15 Answers
SOURCE: Gateway MX8738 Laptop won't power on. The power
Sounds like your power jack may be faulty or bad connection to motherboard unfortunately. The only way to truly find out is by disassembling the laptop. You'll have to do this at your own risk of course, and test the terminals at the power jack to see if you are getting power through them, if you are, then the trouble is deeper in the motherboard. If you are not, then here is a good article on how to fix the power jack:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Good luck.
Posted on Jul 22, 2010
  • 1531 Answers
SOURCE: I have a 2 1/2
First thing to check is the main power supply and circuit breaker and make sure there is power there.
then check the wiring to make sure there is no problems with that.
last thing is to replace the main control board
Posted on Sep 10, 2010
  • 385 Answers
SOURCE: I have a MP600 printer. Yesterday it worked fine.
Hi there!Had the same thing and after replacing the main board it sorted the problem out!Could have been a spike in power and also a dry joint on the board,It will be cheaper replacing the printer than replacing the main board!Sorry!!
Posted on Oct 20, 2010
Electrolux vacuum ergospace stop working how to fix
I am not too familiar with this particular model but I would think the cord winder may be shorting out. I think you can take it apart by turning it on its side, pull the side strips off. It is a bit tricky but if you access the winder check the electrical conitinuity from the winder to the plug in cord. You are probably better to take it in but if you cant please be careful to not get a shock..
Jan 16, 2014 | Electrolux EL4100A Ergospace Cannister...
Electrolux washer dryer EWX14440W. It just seems to have died. No power, noise, lights, error codes or other signs of life. Can anyone advise where to start?
check fuse in plug ,check main circuit breaker tripped also do u have a neon switch on wall in room check this fuse also, to check scoket out let plug some thing else thats works to check out scoket out let
Aug 31, 2013 | Electrolux Washing Machines
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
Will the aspire 5735 start up with a dead battery
A dead battery will usually stop a laptop from starting up. Remove the battery and try running from the power adaptor alone. If this works you can be sure the battery is dead.
Apr 10, 2010 | Acer Aspire 5735 Notebook
Jan 15, 2010 | Electrolux Vacuums
My Electrolux series 3500 SR won't power on.
Most likely the cord has a broken wire you can't see (near the plug) or; the switch is bad.
Either is a fairly simple repair.
Charlie
Aug 21, 2009 | Electrolux Epic 3500 Vacuum
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
