Question about Dell Inspiron 1501 Notebook
When i turn the computer on it says it doesn't recognize the battery
  • 661 Answers
Your battery is likely dead. I assume it is the CMOS battery. Replace that and you should be fine.
Posted on Apr 01, 2011
Computer doesn't recognize camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Dec 18, 2012 | Nikon D3000 Digital Camera
My Cowon D3 is frozen and my computer doesn't recognize it. What do I do now?
Have you tried restarting your device by removing the battery? Also if you are running vista, you may need to download the driver files from the manufacturer's website.
Sep 16, 2012 | Cowon D3 MP3 Player
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
While i was trying to update my nokia n73 turned off and now i can't turn it on,and my pc doesn't recognize when i connect the phone turned off
Did the update finished with out an error?check your battery,if the battery is too drained,you won't able to charge the phone.If this method doesn't works,there's a problem on the update process.
to be able to retrieve your phone,ask assistance to a mobile phone service near you.they will glad to assist you on your problem..
Jun 12, 2011 | Nokia N73 Cellular Phone
Dell Inspiron 1501 Notebook Logo
Alun Cox
