Question about Motorola Mobility Clutch i465 Cell Phone
Motorola i465 self check fail 02000 RA4 00 01
Would like to unlock this phone so it can work in Jamaica
The Motorola Locked in which Network in which Country?what is the IMEI Number,You can Unlock it using the Subsidy Code or Unlock code,get the Paid safe code from
Unlocking4u.com and unlock it step by step following the instruction below:then You can use it in any GSM NETWORK in Jamaica Country...
Motorola CLutch i465 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola CLutch i465 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola CLutch i465 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola CLutch i465 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola CLutch i465 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola CLutch i465 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Each Motorola CLutch i465 mobile phone has an unique unlock code. You can buy the unique unlock code for your Motorola CLutch i465 mobile phone using the form above.
Jun 04, 2011 | Motorola Mobility Clutch i465 Cell Phone
Locked out of the phone its self i465
if the automatic keypad lock is what concerns you about, you can change its setting to manual keypad lock. you can access it at its phone menu settings. navigate to the menu until you will find keypad setting option or the like...
Jan 01, 2011 | Motorola Mobility Clutch i465 Cell Phone
Unlock motorola1465
To Unlock the Motorola I465 model mobile....You can use the Unlock code,You can get the Unlock code here
http://www.wickedunlock.com/motorola-i465/rs11wp9/ at reliable cost and Unlock it................You need to Check Unlock Code for Your Mobile Locked Network,Country,....
Nov 07, 2010 | Motorola Mobility Clutch i465 Cell Phone
Charging...
no, you should take it to the place you purchased the phone at, or take it to the nearest/ most conviniant place and ask for them to check it out, if they cant find anything wrong with it, i sujest getting a new phone all together,
p.s there might be a problem with the battery its self.
Apr 25, 2010 | Motorola Mobility Clutch i465 Cell Phone
Doing a self check
its fatal error
pls show your phone to nearest phone repairer
Mar 17, 2008 | Motorola Mobility i580 Cellular Phone
Motorola Mobility Clutch i465 Cell Phone Logo
418 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
