Question about Acer Aspire 5720 Notebook
Computer going to the loading screen then going back through the cycle
  • 661 Answers
If you mean it keeps restarting, there is a very good chance your hard disk suffered a head crash.
Posted on Apr 01, 2011
  • Eddie Chen Apr 01, 2011
    If that is the case, you may need to replace the hard drive.
Dell error code 652F:0119
have you tried the original dimms put them back in and see what happens. if the same thing happens then windows is looping ie going round getting to a point forgets what to do so it restarts the only way around this is a reinstall of your os.
Jan 28, 2014 | Computers & Internet
Sony pcv-rs520 boot bios - need BIOS entry key for changing boot drive
Should be the F2 key to enter setup. Make sure you are pressing this key during the VAIO spash screen on boot. If you press it after the spash screen the bois will not load and you will have to power cycle the computer to get the spash sreen back and try again.
Feb 20, 2012 | Computers & Internet
Washer is stuck at 45 minues
Check the inlet screen on the cold water hose. Turn off the cold valve by the inlet hose, disconnect the hose from the back of the machine, and look for a plugged screen inside the hose thread nipple on the back of the machine. Remove screen, clean it out, replace screen, hose, and turn water back on.
May 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Cycle takes forever
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
Jan 25, 2010 | LG WM1814CW Front Load Washer
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 29, 2009 | Apple iPhone 3G
Dell Repeatedly Restarting in a cycle
Hi ,
Do you have an Antivirus installed , if yes kindly scan the drive , It happens also due to virus in your PC .
May 10, 2009 | Dell XPS M1530 Laptop
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Computer keeps cycling off and on
Load defaults on the bios screen, save and exit, reboot. see if it recognizes your newly installed ram. also if you have 4 memory slots, try using different configuration on the placement of the ram modules. Like if you have four memory slots trying, try using the first and 2nd slot, if no go then try using the 1st and 3rd slot and also remember to always load bios deafaults everytime you reconfigure the ram placement or size.
Feb 19, 2008 | E-Machines eMachines Desktop PC
Acer Aspire 5720 Notebook Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
