Question about Acer AL1717 17" LCD Monitor
My lcd monitor AL1717 has initial blinkig &there is no display,after some times it works properly,what is problem.
  • 656 Answers
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
Posted on Apr 01, 2011
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
Sudden failure - working fine then next time switched on no apparent power (no indicator light on), no display
You could have a power supply problem in the LCD monitor.
First check the power lead, make sure it is firmly inserted into the mains socket and into the monitor.
Try inserting it into a different main socket that is operating, to see if the power indicator LED lights up.
If you have determined it is the LCD monitor is faulty, then it requires repairing.
Jan 25, 2011 | Acer AL1717 17" LCD Monitor
My al1717 green lines in display
the complaint of display, please change the lcd display,be carefully
Dec 12, 2010 | Acer AL1717 17" LCD Monitor
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show...
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
Oct 09, 2010 | Acer AL1717 17" LCD Monitor
Vertical Red Line down the screen of my Acer Al1717.
Try hooking an external monitor. If it will still show on the other display, possibly it is a video card problem. But I highly doubt it. Usually for this issue, it will have a good display on an external monitor. Try if it will still appear n the BIOS page. Press F2 several times immediately after turning the computer on. If problem still shows there, then it is the LCD that is causing it to happen. You need to replace the LCD.
Sep 21, 2010 | Acer 17" AL1717 Flat Panel Color LCD...
There is a thin yellow horizontal line on my right display
This is definitely a hardware problem. Either your AGP/video card is not functioning properly. But the more likely problem is that your monitor color blending function in that particular line is not working.
You need to get the monitor check by an expert technician. Don't take chances.
Nov 16, 2009 | Acer AL1717 17" LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
390 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
