Question about Hotpoint Refrigerators
I have a hotpoint refrigerator model no.HSM25GFRE SA and it's no making ice and water is not coming out when u press the botton. Can u tell me what's the problem is?
2 Suggested Answers
SOURCE: Hotpoint Ice Maker Stopped Making Ice
hotpoint hss25gfpjww stopped making ice..leaking ?rust from under dispenser..please help
Posted on Sep 07, 2009
Hsm25gfre sa
u need to replace the water inlet value
Apr 06, 2014 | Hotpoint Refrigerators
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Feb 14, 2014 | Hotpoint HSS25GFP Side by Side...
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Ge ice marker no 120v to seloniod water valve
It sounds like the plug-in for the solenoid valve is not making contact with the terminals on the solenoid . You can either buy a new connector or cut the plug for the solenoid and crimp 1/4 inch sta-cons (insulated type) to the wires.
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Problems with HOT POINT MODEL# HSM221FTA SA serial# ML211057
Make sure that condenser coil is cleaned even if you have to blow it out with compressed air. Check the freezer compartment for snow on back wall. If you have snow on the back wall you have a defrost system problem. If the water is slow coming out of the dispenser and the ice maker is not making ice it may be a supply water pressure problem. There is a five or on some models a ten year warranty on the compressor. This depends on your make and model which you did not include.
May 06, 2008 | Hotpoint HSS25GFP Side by Side...
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Refrigerators Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
