Question about Polaroid FLM-3225 32 in. LCD Television
Key sign how do I take it key sign on left side of screen?
Google screen only (all other screens are correctly positioned) has moved right, can't access right side of screen. can't adjust
Press the windows key on your keyboard, and while holding it down, press the the left arrow key. that will move it to the left.
Dec 05, 2014 | Google Chrome
There was a percentage sign on the bottom right hand side of screen to increase or decrease the size of viewage
on the keyboard hold the "ctrl" key down and then press the + key to increase the size or press the - key to decrease the size
Apr 14, 2013 | Computers & Internet
How to brighten my laptop screen
There are two 'Brightness signs' on two keys of your laptop keyboard.
Press 'Fn' key (on the last row of the keyboard) and press one of these keys to increase or decrease brightness.
Sep 10, 2011 | Computers & Internet
Just been given a ASUS Eee PC 900, with Linux. It says press the Enter Key, but I can not find a Enter Key as such. What key do I have to press.? Driving me crazy
Well, the Enter key is the one with the symbol of a left-pointing arrow with a short 'up bit' on the right-hand side of it. I think its to the right of the @ sign and on the same row. Incidentally the OTHER left-pointing arrow without the up bit on it is the backspace. Thats up above the Enter key also on the right-hand side of the keyboard. Regards, nicam49
Aug 16, 2011 | ASUS Eee PC 900 Notebook
You have to press 3cm to the right of the intended button on the touch screen. how do you fix it?
Turn the main power switch on the back of the machine off and leave the power switch on the left side on. Make sure no F-rom cards with firmware are in the machine. Press and hold energy saver and function keys down, turn the main power on in the back of the machine continue holding keys for about thirty seconds. The lcd blinks and shows a + on the upper left, press the + sign then one + sign on lower right edge and then one + sign in the middle. If the + sign goes away try the procedure again. Once it is calibrated reboot the machine and touch the Lcd in different spots to see how it works. Hope this helps.
Jun 30, 2011 | Panasonic DP-8045 Grayscale Copier
How do i padlock my phone
Do you mean Key Pad Lock? if it is so then follow .... Return to the Screen mode by pressing the RED button on the Right Side - Press the Green button on the Left side just above 1 and again press star * but you should do it within 5-10 seconds .. marvinii22.jpg?w=360&h=480 Good Luck
Apr 30, 2010 | Nokia 6600
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
How do you put the LG VOYAGER VX10000 on vibrate
the other solution is not what i think they are asking.
there are many ways to put the phone on vibrate:
1. closed: press the phone icon and hold the # sign.
2. open: hold down the Z key from the main screen.
3. open or closed: press the down volume key on the left side of the phone until it says vibrate.
Feb 24, 2009 | LG VOYAGER VX10000 Cellular Phone
Polaroid FLM-3225 32 in. LCD Television Logo
14 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
