Question about Ryobi 18v 38" One+ Cordless Drill P205 18 Volt V
Cant seem to drill into concrete with tapcon bit in 18V P205. What settings and speed do I use?
    Problem Solver:
  • 9 Answers
You should be able to drill at a low speed. Maybe 100-200 rpm. I assume the bit is sharp. I have run into an ocassional new bit that is bad. If it suddenly stops drilling you may have hit a rock. Crack the rock with a center punch then continue drilling.
Posted on Apr 01, 2011
Ryobi 18v Lithium cordless impact drill chuck comes loose while drilling
Tighten the screw inside were the drill bits or attachments go this is a reverse threaded screw try using lock tight also
Aug 31, 2013 | Ryobi 18v Variable Speed Impact Driver...
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
I have a Dewalt DCD770KL 18v LiOn drill/hammerdrill. I did not use it much for drilling into concrete before, but recently, I needed to mount something to the ground. I used the hammerdrill setting and...
Please visit a qualified technician. Because it's also my personal experienced with hammer drill that inside a small ball bearing with tiny spring as a tosser for shifting always been stocked up by sticky or hardening grease which you need to loosen. If not kindly check it up for something that is blocking the shift. Thanks for asking.
Jun 13, 2011 | DeWalt DCD770KL 18Volt Cordless 12Inch...
I have drilled a 1 inch hole in my concrete basement wall. I cannot release the bit from the drill. The chuck won't turn by hand to release the bit.
Good Afternoon, Ladooudep55:
I hope you have got your bit back, but if not, remount the drill chuch onto the bit, and drill in forward without pushing the bit. If it still won't move, You can gently wobble the drill to enlarge the hole and retrieve the bit.
The other method is alternating light hammer taps with compressed air. It will make lots of grit dust.
If the hole around the bit is wet, you may have drilled into an iron pipe, if it smells it was the sewer drain. You will have to decide if you want to replace the pipe section or run an epoxy patch once you have retrieved the bit.
Chr
May 01, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
What are the numbers around chuck used for?
They refer to the relative tightness of the adjustable built in clutch. The lower the number, the less torque is applied before the clutch starts to slip. At the drill image on the ring, there is no slippage.
Why would you want such a thing??? Well because you don't want to strip a screw yo are installing or possibly break it. Whether you are putting small screws into soft wood or you are installing "TapCons" in concrete, this is a very good feature to have on your DeWalt or other fine battery powered device.
I hope this answers your question ... Please remember to rate this answer. The rating is the only "pay" I get here as a volunteer question catcher./
Thank you for your interest in FixYa.com
Mar 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
We are only managing to drill 4 x 6mm holes in paveing slabs, drill is 18v and only 1month old.
Ryobi is one of the cheapest drills. They are good for small projects. You need to upgrade to a better drill like milwalkie or Dewalt. Seems if you are drilling in concrete you need a corded hammerdrill. This will get the job done.
Dec 08, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
When in drill mode the tork still kicks in on my dewalt
clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Apr 22, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Ryobi 18v 38" One+ Cordless Drill  P205 18 Volt V Logo
191 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
