Question about NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
How to divert call to a mobile - NEC ETJ 16DD-1 Corded Phone (necetj16dd-1)
  • paulheppel Apr 01, 2011
    how to divert call to a mobile
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
Jun 07, 2014 | Apple iPhone 5c
I can't recieve calls on my e63
Seems your mobile received calls have been diverted,
Go to your mobile settings,then to call settings ,then to CALL DIVERT,then chose the option :
CANCEL ALL DIVERTS.
Jun 04, 2011 | Nokia E63 Cell Phone
How can I divert calls to my mobile? thanks
Hi..
To make an call divert , you have tweak your phone call divert settings in such a way that every call is diverted to your mobile. You can read the instruction manual for help.Provided your machine should have an option of call diversion ....
thanks for rating
Jun 02, 2011 | Cell Phones
Call divert active i canot deactive
To deactivate your call diverts, go to 'settings' on your phone, 'call settings' and then 'call divert'. When you select it, choose the option to 'canel all diverts'.
If you have done this, and the call divert is still active, then contact your mobile service providers, they would help you fix the problem on the network.
Hope that helps?
Success.
May 12, 2011 | Samsung Star GT-S5233 Cell Phone
How will you activate call divert
Go to menu > settings > call settings > call divert.
Choose your method of call divert, choose activate, select the phone number you want to divert the call to or voice mailbox number and that's all.
I hope you understand the above....
Good luck.
Mar 07, 2011 | Nokia 2626 Mobile Phone
How do I divert calls on my mobile when I am
*21*<mobile no. where u want to divert>#
where star(*) and hash(#) are available on keypad
to cancle the divert
press
##002#
Oct 15, 2009 | Alcatel Virgin Mobile ?£30 Text Cellular...
Can't turn off call divert?
open menu, select settings and select call.
In this there is option call divert, select that.
In that select cancel all divert or select option and in that select cancel all divert. by doing this your problem will get solved....100%
Apr 23, 2009 | Nokia 6300 Cell Phone
Call Divert
The following codes are for call diverts:
Divert when busy: **67*(phone number)# then press call
To cancel it: ##67# then press call
Divert when out of reach: **62*(phone number)# then press call
To cancel it: ##62# then press call
Dec 29, 2007 | Apple iPhone Smartphone
Call managing
Try to see if your phone has a Call divert Feature. 1. You can Divert all voice calls 2. You can Divert if busy 3. Divert if not answered 4. Divert if out of reach 5. Divert if not available
Jul 20, 2007 | Nokia 1100
NEC ETJ 16DD-1 Corded Phone (necetj16dd-1) Logo
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
