Question about Dell OptiPlex GX280 PC Desktop
I have a dell gx280 model it does not boot and when switch on the fan makes a lot of noise.what can be the cause?
  • 661 Answers
Sounds like a classic case of overheating. Check the thermal compound under the heatsinks and replace it with Arctic silver 5
Posted on Apr 01, 2011
Dell Optiplex GX280 has very high processor fan noise.
Hi
Generally Dells run very quietly, so there are three possible problems here.
The first is that excessive noise can be caused by the fans having to run faster than usual to keep the temperature down. In this case you need to check and make sure that all the airways and interior of the computer are clean and clear of dust, which can build up in such a way as to seriously obstruct airflow. If this doesn't help there are normally at least 2 fans in the computer, one for the CPU chip and the other in the Power Supply. If it definitely one of these the only real way to cure it is to replace whichever is causing the problem.
You can download a very comprehensive manual for the GX280 here:
Product Support Dell US
by clicking on the "Users' Guide" link. This will download a pdf file which can be saved to your drive for future reference. The manual contains detailed instructions for these types of things, easily accessed by an interactive menu system.
Since this is quite an elderly system, you may find, that after pricing any replacements necessary to cure the noise, it makes more economic sense to put the cash towards a more up-to-date system.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Dell Computers & Internet
Gx280 powers up but no boot cpu fan runs out of control
Usually faulty ram chip / chips. Check that they are making good connection first.
Jan 18, 2013 | Dell OptiPlex GX280 PC Desktop
Dell xps 420 noisy fan black screen
more than likely bios isn't letting it boot, i'd make sure the fan bearing hasn't gone out, if it has you can order a new one
Jul 03, 2012 | Dell XPS 420 PC Desktop
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell optiplex gx280 makes loud fan sound at startup and enters windows screen, but will not finish booting and freezes up.
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Jun 12, 2009 | Dell OptiPlex GX280 PC Desktop
GX280 - is it the motherboard?
Go here and download this program.
http://www.download.com/SpeedFan/3000-2094_4-10067444.html
This program will control your fan speed based on your cpu temp. It's main use is to quiet fan noise.
Dec 15, 2008 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Nov 16, 2008 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
98 people viewed this question
Alun Cox
