Sony kdl xbr9 blue vertical line goes away after 20 min
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
Posted on Nov 23, 2009
  • 668 Answers
SOURCE: sony bravia kdl-32l4000 has colored vertical lines
Most of the time the " T-Con" board is the cause. On a lot the Sony models, this board is not replaceable without replacing the LCD Panel. Sony has been making more of them available but you would need to check with Sony's Parts Department if it is available for your Model.
I hope this helps,
Sky Assoc
Posted on Jan 05, 2010
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
Sony kdl 55xbr8 vertical lines
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 02, 2014 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
I have a Sony Bravia KDL-52XBR4 LCD TV.
Sure, but not at minimal cost - it's a sony! Probably the t con board.
Sep 17, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites Shopjimmmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Oct 29, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
I have a sony Bravia 46" When I first turn the TV on it has vertical lines on the left side of the TV after babout 5 min they go away?
its called burn in and yes it can go away over time. Be sure to not leave a static image on the screen (like a paused video) and leave it for an extended period of time.
playing video with high brightness and fast moving action can further help the problem go away.
Oct 23, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
