Question about Coralife Power Center DayNight Timer or WaveMaker Timer Life Support
My coralife powercenters dial is not functioning properly. It keeps lagging behing in time and is not turning on the lights automatically any more. Is there a coralife replacement number or anything of the sort?
If analog dial-timer is lagging, then clock motor has gotten weak and is overheating and will stop working. There are no replacement parts for this timer.
Open following link to identify timer, download manual and link to Specialty Products
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 01, 2011
Power strip cuts off power to tank same day every day
Timer has gone bad, or polarity of outlet is incorrect, or voltage is incorrect, or all above.
Copy following link for product manuals and possible warranty:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
Jun 11, 2012 | Coralife Zilla Aqualight Power Center
My Coralife single Power Center, requires time correction at least weekly, if not corrected it well be several hours off with a week or two. I think this to be out of design specifications, and should be...
If timer is new, then it has 1 year limited warranty.
Analog timers have small clock motor that rotates dial, and the motor gets slow as it ages.
Sometimes the motor sticks at the tripper, instead of pushing the on-off lever.
There are no replacement clock modules for this timer.
Try timer on different outlet and different circuit breaker and on different load to check if outlet polarity or load noise is causing problem.
If more than one timer has same problem, test outlet with circuit analyzer.
Aug 11, 2011 | Coralife Power Center DayNight Timer or...
Cant change time on coralife power bar. how do i do this?
It depends on which Zilla product you have.
Resourceful do-it-yourselfer can add a comment after identifying product on following link and downloading manual.
1) Digital timer has to be programmed.
If timer worked correctly before, and stopped working you might need AG13 replacement battery.
Or take battery out for several minutes to reset timer.
If timer will not reset or program with new battery, timer might have gone bad.
You can also use cheap circuit analyzer and check that circuit is clean and not interfering with timer electronics.
Programming manual on link above is best place to start for programming steps, and then add a comment if you are stuck on particular part of manual.
2) Analog timer has segments located on dial.
These segments are lifted up or pushed down to control on-off functions.
You can pull a few segments up and leave others down and then manually rotate dial clockwise to observe when power turns on-off. This will tell you exactly how to set segments.
3) All models of Zilla power strips are 2-channel.
Each have blue and yellow outlets, and each color correspond strictly to day or night.
Daytime outlets are blue.
Nighttime outlets are yellow.
Add a comment for more free help.
Mar 15, 2011 | Coralife Zilla Aqualight Power Center
I have both plugs in the yellow outlet and trying to put them on automatic setting and it wont do it. I need the light to be on at 5am to 11pm and it is not automatically doing it. What do i need to do to...
1) View Zilla product and manuals at following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#Zilla
2) Zilla is aquarium timer, and astronomic-type timer, and 2-channel timer, that breaks 24-hour day into strict night and day settings.
3) Manual says: both yellow and blue outlets cannot be on at the same time
Yellow outlets are daytime hours.
Blue outlets nighttime hours.
If you have analog timer, daytime hours show on dial with dark background.
4) You need to plug into both blue and yellow outlets to set times that run continuously from 5am to 11pm.
5) To solve problem might require different timer altogether.
Link posted above shows different Utilitec, Woods, Westek, and GE power strips models that might suit your exact purpose better.
Feb 28, 2011 | Coralife Zilla Aqualight Power Center
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
I have a T101 Mechanical timer that isn't working properly. The clock seems to be working fine, and if you turn it to manual, the lights come on. However, the lights do not turn on automatically. Any...
First be sure dial is actually turning. Are the trippers tight on the dial? Sometimes when the gears and motors are going bad, the dial will turn until it gets to the tripper, then stops. It doesn't have enough forct to trip the switch. You can buy just a motor if that's the problem. www.intermatic.com
Aug 18, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
I am having problems setting up coralife aqualight power center
You need to plug them into the two yellow outlets, not the blue ones. The blue outlets are for night lights if you have them. Set the timer for 6 and stop at 12am. If you plug them into the two yellow outlets they should go on at 6 and turn off at 12, however If you also plug something into the blue outlets they will turn on as soon as the yellow outlets turn off, it's sopposed to switch from your day lights to your night moon lights automatically provided you got the moon lights plugged in the blue outlets. Hope this helps....
Jun 01, 2010 | Coralife Zilla Aqualight Power Center
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Coralife Power Center DayNight Timer or WaveMaker Timer  Life Support Logo
90 people viewed this question
Top Coralife Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Coralife Hardware and Accessory Expert? Answer questions, earn points and help others
