Question about LG LFX25960ST Stainless Steel French Door Refrigerator
The fridge is giving off a rotten gas odour, the fan has been replaced with no effect. Also the fridge has been turning off, electronic display showing 6/7 on the freezer lights only.
  • LG Master
  • 43,501 Answers
It sounds like the start components on the compressor are burning up...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
Bad smell comming out of vents Acadia 11
should a tenant have to tolerate a putrid odour from an outside vent caused by natural gas?
Sep 25, 2012 | 2011 GMC Acadia
My side by side refrigerator exhaust at the bottom of the fridge is expelling an odour. Is there a solution and is it a health risk
i guess if the odour is bad is not good . generaly caused by bact or who knows what . but let me say this / most smells that come from under frig are the water in the evap pan . and should be removed and cleaned several times a year . other are mice in insulation and sometimes the fan get's them . so slid it out and clean it out / it will run better when cleaned . the coiles do get dirty and the fans slow down .. hope this helped **** ..
Feb 23, 2010 | Refrigerators
The fridge is producing a bad odour from some
The odor is coming from the defrost liquid Throw it away and clean the interior of the refrigerator with detergent and remove moisture. Dry it by opening the door for about 3 or 4 hours and then set the
temperature control button at strong.
Oct 26, 2009 | LG Refrigerators
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
May 10, 2009 | Refrigerators
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Fan blows out a smell from underneath fridge could it be leaking gas.
call the repairman back and say forget it ,on the motor youll see a flat pan ,like a cookie sheet on top ,the excess water from the freezer drains into a tube and into that pan as the motor gets hot it evaporates the water,just clean the pan,shut down fridge,unplug and let motor cool,clean the pan and tell hubby not to waste good beer lol
Apr 30, 2008 | Frigidaire FRT18B4A Top Freezer...
Tray at the back
IS THIS TRAY ON TOP OF THE COMPRESSOR ? IF IT IS THE HEAT FROM THE COMPRESSOR SHOULD EVAPORATE IT... IF IT IS NOT THEN TRY HAVING A DRIAN HEATER INSTALLED IN IT YOU CAN BUY THEM AT ANY APPLIANCES SERVICE PARTS HOUSE THEY USE THEM FOR COMMERICAL UNITS HAVE A SERVICE TECH DO THE JOB
Aug 26, 2007 | Admiral 26 cu. ft. Side-By-Side...
I have the same problem with the odor. I took the back off and discovered the drip pan was full of stagnant dirty water. This place is bacteria heaven. The problem I have now is that i cant seem to find a way to remove the pan without taking the motor out and everything. Any suggestions?
Roman
Jul 02, 2006 | Whirlpool GD2SHGX Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
80 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
