Question about Acer Computers & Internet
I have a acer aspire x1700 that will not boot gives me a message that says windows failed to start status 0xc0000034. it will not run a disk
  • 21 Answers
You can try two things:
1. Boot up and Immediately begin tapping the F8 key. When the Option menu comes up select "Last known good configuration"
2. Sounds like you need to reboot using your windows recovery disc.
If it will not boot up using the disc, try again but press F12 while booting (Sometimes F2 or Del) to get into the Bios settings. Here you can tell the computer to boot up from a disc.
When booted, select Repair your Computer.
Posted on Apr 01, 2011
Status 0xc000000f
You should be able to create a boot able stick for this kind of issue.
Sounds like you have hard disk errors. Open the Command Prompt when the Installation DVD Loads and type the following commands.
chkdsk /r c:
chkdsk /r d:
chkdsk /r e:
chkdsk /r f:
.etc until you get the message that the volume could not be opened for direct access. For any drives that do not give the message:
"Windows has checked the file system and found no problems"
run chkdsk again as above. In other words, if it says:
"Windows has made corrections to the file system"
after running the disk check, run the disk check again.
I realize you may only have one disk show up in Windows explorer, but you may have more than one disk through recovery options. This is because the system creates a hidden boot partition (which will be C: in recovery), you may have a recovery partition for your PC that is hidden (which will be D: in recovery), and you will have your primary Windows partition (which may be E: in recovery). A custom PC will likely have at least C: and D: to scan.
Nov 01, 2013 | Acer Computers & Internet
Windows failed to start, Status 0xc000000f acer aspire 4730z
aspire aspire d257 status 0xc000000f Info: the select entry could not be loaded because the application is missing or corrupt
Jun 30, 2012 | Acer Computers & Internet
Acer Aspire X1700 Desktop Wont Start up Shut down with blue Protection screen
That's Blue Screen of Death. Start up ur pc in safemode by pressing F8 key while booting and uninstall any recent hardware or software installations. Or try System Restore to an earlier date. If u failed to boot up ur pc even in Safemode, make a clean and fresh OS installation.
Jul 28, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
UNMOUNTABLE DISK VOLUME Message on ACER Aspire One.
Unmountable boot volume is most likely an indication of a failing hard drive. Boot to your Windows CD and run CHKDSK /R and see if issue resolves. If it doesn't then you are probably replacing the hard drive.
Sep 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer travelmate5720 fat32 problem blue screen
Sounds like the hard drive is starting to fail. Do you hear and occasional 'click-click', 'click-click'?. A new hard disk should solve the problem
Jul 23, 2009 | Acer Aspire One PC Notebook
Windows boot manager file: /boot/bcd status: oxcoooooe9 info: an unexpected I/o error has occurred I am experiencing the same problem on a Dell laptop (Inspiron 1525: Windows boot manager - file:...
Try check your hard disk with the other machine. Try running hard disk diagnostic test. If there's a problem with diagnostic test i suspect your hard disk is faulty. If you tried connecting with other machine then same problem, suspected also hard disk faulty. You might need to change it.
May 09, 2009 | Dell Inspiron 1525 Laptop
Acer 5100 Vista Boot up issue
sounds like you need to reinstall the operating system. if you don't have the disk you can call acer and they will send you the disk. they might charge you for the disk usually between $15 and $30.
Mar 01, 2009 | Acer Aspire 5100 Notebook
Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 21, 2008 | Computers & Internet
Repair
i think this is a os problem or hardisk problem change check hard disk
Oct 23, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
286 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
