Hi i have a samsun top loder washing machine wen i prest sart it wont start keeps beeping and i just displays DE how can i fix this
    Genius:
  • 1,400 Answers
Hello
This code means door error.There is a problem with your door magnet or switch not making contact or closing the loop to allow washer to start.
Try cleaning off the magnet if there is one,or checking that the switch itself is not loose or broken.
Please unplug machine before doing any of the above.
Posted on Apr 01, 2011
AFTER STARTING THE MACHINE IT SHOWS ERROR AS "de"
There are numbers of error which washings machines shows output.The machine identifies and indicates some operational errors through a series of beeps.Beep is given below for you are reference.
Display indication what to do
DE Unhook/clean drain pipe and press the 'start/Pause' button to
continue cycle.
Thanks for your question.
Jun 17, 2011 | Washing Machines
Top loader MW511 will not start. Wash Progress (where you select wash type eg long or short) is the only display with lights showing, and I cannot change anything despite pressing the button to do so. No...
Hi just read your posting.Now on that wash progress line of lights there are 8 lights in total.Starting from the far right what lights are lit up?Is it the 2nd and 5th or the 4th and 8th--etc---?With this additional information I can work out the error code and advise you how to repair this fault.Please reply for further help.
Jun 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Dec 07, 2008 | Washing Machines
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
De is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
Mar 12, 2008 | LG WM-1480FHD Front Load Washer
Samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Nov 06, 2007 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
