Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I ORDERED A NEW BELT THE OTHER ONE BROKE I CANT AND MY HANDY MAN CAN NOT GET THE BELT ON. ANY SUGGESTIONS THANK YOU
How can i make my roll brush move on my eureka vacumn AS1101 A the belt is not broke so why wouldnt it work
My issue is that the belt circled spins independently of the main drive belt. Main drive belt will spin fine but 2nd belt does not engage or soon if there is any resistance...like the ground.
What are you suggestions from here?
Sep 02, 2012 | Vacuums
Better bar doesn't rotate, kenmore whispertone 100
Most likely your belt wore out and broke.
Here is a handy vacuum repair tutorial that should get you back cleaning.
Below is a short excerpt from the instructions. The link above will take you to the full version with images.
When your vacuum starts to lose cleaning power, requiring multiple passes to get an area clean, or the self-propulsion loses its zip, chances are you need to change the vacuum agitator belt. After only a few months of use, most vacuum belts stretch out enough to slip, causing the agitator to spin more slowly.
Replacing the belt is quick and inexpensive. New belts are available starting at about $5. Belts come in numerous brands and sizes, so bring the old one to the store for a guaranteed match.
Fifteen minutes, two screwdrivers and a new belt are all you’ll typically need to complete the job.
Sep 09, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
I need to buy at least 2 new belts for my vacuum.
You can order belts online from http://www.totalvac.com/parts/BR-1007.html
May 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
The belt broke on my my SHARK Model V15Z and Euro Pro hasn't responded to my request for a new belt w/ directions as how to effect repairs.
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
Feb 28, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
We broke our infinity shark vacume belt
You need to go here and order your belts
http://www.sharkvac.com/partsearch.aspx?CatID=cxmdqvOilfw%3d
Feb 14, 2009 | Euro-Pro NV31 Infinity Vacuum
I require a new drive belt for my upright vacuum cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698244
Generic problem for all Vacuums
Posted by martiy on Jun 23, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
