Question about Whirlpool Washing Machines
AWM 321 will not spin. Would you kindly let me know which part I need to replace. I fully accept that you cannot be responsible for any errors. Thank you Alan Morton
  • Whirlpool Master
  • 1,527 Answers
Hello check the pump first it has to drain before it spins if the pump is ok then the cause could be the module board this control the motor speed usually sit at the back of the washer may have a load of wires coming off it. if the this ok the brushes on the motor can cause spin problems
hope it helps
regards
shaun
Posted on Apr 01, 2011
Getting error code 004-321 on my dell 3100cn. How do I fix it? Wont let me spin the drum and don't know how to take it out.
the belt inside the drum has moved to one side and the printer can't read the magnetic patch on the belt. open the drum and move the belt over and replace it , then turn it on,... it will keep doing this, so you will need to replace the drum...
Oct 19, 2010 | Dell 3100cn Laser Printer
F07-AWM 9000
The F07 indicates a Motor Control Unit (MCU) Error.
  1. Disconnect mains power and unplug unit.
  2. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  3. Check the MCU
  4. Check the Drive Motor
  5. Check the Wire Harness
  6. Reconnect power and plug unit in.
  7. Check the MCU operation by looking for movement of the drive motor, and check drive motor for fully powered rotation.
  8. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re select cycle and select HOLD TO START.
Oct 26, 2009 | Whirlpool AWM9000 Front Load Washer
Trouble with it spinning
hi..It is probably due to the belt.you may need to replace
it with a new one.
check it out..
thank you..
kindly rate my response..
Jul 19, 2009 | LG Washing Machines
Whirlpool Cabrio has started displaying error F50 - will not spin.
hi..the reason to this problem is the RPS(Rotory positon
sensor).
check it out..
thank u..
Jun 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My dyson DC07 has no suction. motor runs, brush spins, just no suction.
hi..the reason to this problem may be the bottom pieces
might not have been fully seated.Take it apart and put it
carefully back together.This will solve the issue.
check it out..
thank u..
Jun 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
F 19 error on Whirlpool AWM 8085
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 01, 2008 | Whirlpool AWM8163 Front Load Washer
Error code of ricoh af1053SC 321.322. 326
To my knowledge below error codes refer to:
1. 321 - No Laser Writing Signal (F-Gate)
Error-1 Transfer Belt Signal Error
2. 322 - 1st Laser Synchronization Signal Error
3. 326 - 2nd Laser Synchronization Error
G Gate 2 Error
This would be a possible Laser failure or the transfer belt and would require service confirmation and possibly replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 04, 2008 | Office Equipment & Supplies
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
192 people viewed this question
Dan Webster
Dan Webster
Sal De
