Question about Cobra 148 GTL 120-Channels Base CB Radio
I need to no wich of the pins on mike are ground
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
The outside metal around 4 or 5 pins is usually ground. Black wires indicate ground.
Posted on Apr 05, 2011
Need diagram for turner +3 desk mike 8 pin to ts140s
Turner +3 to Kenwood TS140S
Pin 1 is White (audio)
Pin 2 is Black (Transmit/Keyup)
Pin 7 is Shield (Common/Ground)
Aug 15, 2014 | Radio Communications
Plug it in and put a meter on it. Easiest way to check it is that way.
Mar 12, 2014 | Garmin Power/Data Cable 19-Pin replacement...
Im trying to wire a road king mike to corba 29,i got key up but no auido,wich wires do i change
you would have to look at the wires in the mic also. 99% are wired for cobras./galaxy's etc..
just follow the audio wire and put on pin 2.. grounds on pin 1 tx on pin 3 rx on pin 4
Feb 20, 2011 | Radio Communications
I have a cobra 148gtl with 5 pin side plug for mic.Im trying to wire a superstar dm 1000 echo mic to it,red,yellow,blue,white,& unsheilded wires dont know were they go.???????
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Jan 20, 2010 | Cobra Radio Communications
I have a d845gvfn intel motherboard. wires at bottom beneith the battery were pulled out...wich one goes where?
I'll help you with this issue but it is advised you download the manual for the Intel D845GVFN MB. The manual is in pdf format. You'll need Adobe reader to view the manual. Adobe reader is free. Open the link for Adobe, download and install it; http://www.adobe.com/products/reader/
Provided next is the manual link from Intel; http://downloadmirror.intel.com/15211/eng/D845GVFN_ProductGuide_English.pdf
See page 11, Item O. See page 12 for description. (Auxiliary front panel power LED connector). If you setup the Front Panel Header as shown on page 31 item C. You shouldn't need to connect item D, Alternate power LED. If you're board does not power up than do connect item D.
Pin one should be positive and pin two should be negative. The wire colors define + and -. Wire colors do vary from case to case. Normally colors as red, blue and green are found to be positive. The color white and black are common for ground -. Check item C. You'll find a common color for each connection. This common color is ground.
On the odds if after you connect item D fails you can switch off the PS and switch the connectors. Item D and C use 5volt DC. A few seconds in the wrong position will not damage the motherboard.
Good luck
Mike
Jan 09, 2010 | Intel Computers & Internet
Its a mk1 148 i have just bought it and need to know how to colour wire a standard k40 mike in as in wich wires where.not much experience.a picture would be helpfull
no need colors. look at the switch and plug to verify them. on 4pin cobras/galaxy/connex radios
pin 1 ground
pin 2 audio
pin 3 TX
pin 4 RX cobras
Dec 09, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Need a mike wireing diagram for a kenwood trio ts700g transceiver
Hi Mikeymc_2,
With the Connection pins on the plug facing you and the Locating groove in the 6 o'clock position, the pins are numbered from 1 - 4 in an anti clockwise direction.
Pin #1 Microphone
Pin #2 PTT
Pin #3 Chassis Ground
Pin #4 Microphone Ground
Info is from Kenwood. Subject ; Misc Connectors. 26 / 01 / 99. Hope this helps. 73. REX 9Y4PM.
Any problems contact me at rmclea@tstt.net.tt
Feb 27, 2009 | Computers & Internet
Mike to CB
This has worked for me in the past
Pin 1: Shield and Blue (Mic shield and PTT ground)
Pin 2: White (Mic Audio)
Pin 3: Red (PTT)
Pin 4: No Connection or Mic Return
Note: The Yellow and Black wires are not used.
I hope this helps,
Thank you,
Shuttle83
Nov 03, 2008 | Radio Communications
Farenheit DVD-36 Car DVD need wiring diagram please
USUALLY THE BLACK IS ALWAYS GROUND AND THE RED CARRIES THE FUSE. IF IT DOES NOT SOLVE YOUR PROBLEM I GUESS YOU WILL HAVE TO TAKE IT TO A TECHNICIAN .THANK YOU.
Aug 14, 2008 | Farenheit DVD-36 Car DVD Player
D815 led and etc pins
Looking at page 85 in you're user manual. The 15 pin jumper block. Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G. If you need the manual you can download it from this link.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
Included below is a small pic.
e8e7d5a.jpg Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Cobra 148 GTL 120-Channels Base CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
